NEW PROBLEM(S):
9
10
11
12
13
Topic: NEW PROBLEM(S): (Read 147057 times)
Stewart G Griffin
Re: NEW PROBLEM(S):
Reply #135 on:
April 09, 2009, 07:59:49 pm »
2 separate sizes?
choptop
Extended cab fanatic
Re: NEW PROBLEM(S):
Reply #136 on:
April 09, 2009, 09:09:43 pm »
I think it depends on truck. 1/2 ton is 5/8 i believe
HAULIN IT
Re: NEW PROBLEM(S):
Reply #137 on:
April 09, 2009, 09:17:14 pm »
Yes, Pugsy is correct, the heater core has Two different size nipples 5/8" & 3/4" Lorne
choptop
Re: NEW PROBLEM(S):
Reply #138 on:
April 09, 2009, 09:21:37 pm »
You can tell how long its been since I replace heater hoses on my trucks,lol
Stewart G Griffin
Re: NEW PROBLEM(S):
Reply #139 on:
April 10, 2009, 12:41:31 am »
OK, perhaps i need to back up the train and be more specific:
This is for the test stand and thus i have no heater core. We can see that there is a water outlet(fig.e) on the intake manifold here:
And on the radiator there is an opening(which i've previously plugged, but could unplug if nessesary) here (fig.f)
What do you suggest i should do? Since the outlet "e" is already in the block, i would rather just leave it; Is there a way i could run a short length of hose and plug the hose somehow?
choptop
Re: NEW PROBLEM(S):
Reply #140 on:
April 10, 2009, 06:31:08 am »
I wont run heater hoses on my test stand. You can just take a short peice of hose, and plug the end with a larger bolt and hose clamp, or get a hose nipple and cap from the local harware store and put it in the end of a short hose and use that as a plug for the one in the intake.
123 pugsy
Re: NEW PROBLEM(S):
Reply #141 on:
April 10, 2009, 07:27:37 am »
You have another outlet on the water pump.
Just loop a piece of 3/4" hose to the 2 outlets.
Pugsy
76 C10 LWB
TPI 350
Stewart G Griffin
Re: NEW PROBLEM(S):
Reply #142 on:
April 10, 2009, 10:09:51 am »
That's true.........Duh!
Thanks again.
eventhorizon66
Re: NEW PROBLEM(S):
Reply #143 on:
April 10, 2009, 11:21:55 am »
Why not just plug the manifold too?
'85 C10 SWB 350
700R4
TKO600
Stewart G Griffin
Re: NEW PROBLEM(S):
Reply #144 on:
April 10, 2009, 11:38:40 am »
Well because i figure it's already in there and not leaking and therefore i don't want to take it out and have to put it back in and possibly it might start to leak. i'm like that; i'm the type that likes to pretty much leave things as they are for fear that i might not get it back the way it was even if further adjustment could yield greater benefits.
It's sort of like how alot of people are nervous about taking out distributors. i have since, out of nessesity, gotten over that task however.
eventhorizon66
Re: NEW PROBLEM(S):
Reply #145 on:
April 10, 2009, 11:53:11 am »
Should you have to remove any pipe thread fittings,
this
applied to good clean threads is all you need to ensure a good seal.
'85 C10 SWB 350
700R4
TKO600
Stewart G Griffin
Re: NEW PROBLEM(S):
Reply #146 on:
April 12, 2009, 12:20:53 am »
All hoses done.
If we could revert back to wiring, what about ground?
choptop
Re: NEW PROBLEM(S):
Reply #147 on:
April 12, 2009, 07:14:45 am »
Bolt your battery negative cable to the block. ANy good clean place should work. I usually bolt it to the back of the head on the starter side
Stewart G Griffin
Re: NEW PROBLEM(S):
Reply #148 on:
April 12, 2009, 02:18:36 pm »
System grounded.
Next question, when we want to fill the bowl of the carb before starting, where should we do this at? J, K, or some other place?
choptop
Re: NEW PROBLEM(S):
Reply #149 on:
April 12, 2009, 02:42:10 pm »
j
9
10
11
12
13
NEW PROBLEM(S):
