Body, Glass & Paint
Cant get the mirror to hug the door all the way..
Topic: Cant get the mirror to hug the door all the way.. (Read 18125 times)
treepete
January 01, 2009, 09:38:59 am »
Hey gents I looked around for info on mirrors, and while some was close, nothing matched exactly to my problem.
I have an 83 silverado and it has the smaller sporty mirrors on it. I was looking over the truck and noticed that the mirrors wiggle up and down a bit ( maybe 3/8 inch.)
I thought this would be an easy fix since I had the door panel off.
ANyway, I removed the mirror itself and there is a metal bracket and a piece of rubber under it to protect the paint I would think,.. I removed the bracket and rubber, and there are two plastic rivet things there, that the screws screw into. These two plastic things are stopping my mirror from bolting completely to the door in a flush manner. Can the plastic inserts be eliminated, and replaced with machine screws, nut and washer inside the door, or is that trouble? how can I remedy this flappy mirror? my only other thought would be to modify the rubber gasket thing to fit around the little plastic inserts.
The metal bracket has a slight arch to it as well, should I hammer that straight wile im in there? or is it a non-issue?
Thanks in advance for your replies, Im just looking for a viable solution I can execute myself.
Pete
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.
www.rccorral.com
Re: Cant get the mirror to hug the door all the way..
January 01, 2009, 09:58:51 am »
Are these what your mirrors are secured to?
click here
⌠ŻŻŻŻŻ' [☼===☼]
treepete
January 01, 2009, 01:09:56 pm »
no although I believe the concept is similar. these are white plastic, appear to have that panel fastner vibe to them. like you press them in and then they just stick. like a wall anchor i guess, but like your picture as well..but plastic/.. sorry so vague.
1983 Silverado
1999 Yukon Denali
www.rccorral.com
treepete
January 02, 2009, 03:08:07 pm »
any other thoughts, maybe?
1983 Silverado
1999 Yukon Denali
www.rccorral.com
January 02, 2009, 03:29:01 pm »
Why don't you try popping them out and using jack nuts instead. They work awesome. Jusput them in the hole, install a bolt and they squash. Then remove the bolt and use the same bolt to install the mirror.
⌠ŻŻŻŻŻ' [☼===☼]
treepete
January 02, 2009, 05:51:07 pm »
ok, I like the way you think. Can i get something like a jack nut at a regular auto parts store, or is it something that I have to buy online? Im sorry to ask this, but Im all new to this restoration thing.
here is what I got. some hacked panel fastner anchors or something..
Last Edit: January 02, 2009, 05:57:04 pm by treepete
1983 Silverado
1999 Yukon Denali
www.rccorral.com
January 02, 2009, 05:57:38 pm »
That isn't what is suppose to hold those mirrors on.
treepete
January 02, 2009, 06:01:08 pm »
man.
I should have known this by the way the PO had the stereo wired.
great. OK.
so jacknuts.. available anywhere?
waitaminnute, Jack Nuts? Didnt he play Bob Rotater, in Days of Thunder, the movie?
I got nuthin'.
Last Edit: January 02, 2009, 06:22:45 pm by Captkaos
1983 Silverado
1999 Yukon Denali
www.rccorral.com
Igosplut
January 02, 2009, 06:28:11 pm »
There's a metal plate that bolts to the inside of the door (right under the vent window track) and has a flat reinforcing plate that the mirror mounting bracket screws to (not the door skin). That's what makes the mirror rigid as the flat plate double-walls the mounting. I can take a picture of one for you if needed so you can find them. It's really the best way of mounting the sport mirrors.....
January 02, 2009, 08:03:36 pm »
yes you can get jack nuts at any decent autoparts store or hardware store. You can also use nuts and bolts.
⌠ŻŻŻŻŻ' [☼===☼]
January 02, 2009, 10:53:33 pm »
I went out an looked today and all my sport mirrors are at Toolmasters garage, so I couldn't get a pic of how the mount, but. Igosplat described it as it should go.
treepete
January 03, 2009, 08:32:51 am »
ok well, right on and thanks for all the replies. Ill take a look today when I go to the hardware store. Im taking that picture VileZambonie sent with me. See if they have something there.
1983 Silverado
1999 Yukon Denali
www.rccorral.com
78BBSTEPSIDE
January 03, 2009, 09:37:59 am »
I have a picture of the factory mounting plate I can email if you would like as I can't get the picture to upload, or if someone can upload the picture I will send it
78BBSTEPSIDE
January 03, 2009, 05:32:51 pm »
Here is the factory mounting hardware for the sport mirrors.
treepete
January 04, 2009, 02:33:41 pm »
ok yeah, I have the small metal part, but it has been "arched" somehow from the PO torquing too much or something.
I do NOT have that piece that appears to go inside the door itself. can you tell me a bit about that part or part set>? Im looking at my mag now and I havent found it yet.
1983 Silverado
1999 Yukon Denali
www.rccorral.com
Body, Glass & Paint
