Author Topic: 6.2 L Diesel  (Read 15556 times)
Offline levisjohnson
6.2 L Diesel
« on: February 11, 2009, 06:23:53 am »
I have looked everywhere.  I found the gauges I like at Autometer but my question is with the diesel.  My cluster has Large Fuel Gauge next to the speedo and a blank place for a gauge on the left side.  I thought about a tach in place of the fuel and put a fuel in the blank.  From what I see, I can not find a tach for my diesel.  If I can not get one, what can I put in the 5 inch hole on the right of my speedo?
any thoughts?
Levis
88 6.2L Diesel 3+3 3/4 ton
Re: 6.2 L Diesel
« Reply #1 on: February 11, 2009, 10:31:05 am »
Re: 6.2 L Diesel
« Reply #2 on: February 11, 2009, 04:34:28 pm »
Thanks
so any tach I get I can hook to the alternator?
here is the instructions for the one I want
http://autometer.com/productPDF/1185.pdf
It says to hook to coil or to a tach terminal for an electronic ignition.  Will it work?
Levis
Offline AdrianR
  • Big Blue Beastie - '85 Suburban K10, 6.2 diesel
Re: 6.2 L Diesel
« Reply #3 on: April 19, 2009, 09:47:12 pm »
...so any tach I get I can hook to the alternator?
I'm jumping in to this thread as I want to do the same as you - replace the 5" fuel gauge on a 6.2 diesel, with a tachometer.
Now, gasser engine tachs work by inductive pickup from the ignition...obviously, that's no good for a diesel. Also, a gasser tach, typically, goes up to 7 or 8000 RPM...for a diesel, that will look silly of the needle never gets past 3000 RPM
But then, after much browsing, I found that Dakota Digital have an adaptor unit that will convert the output pulse from the alternator W/P Terminal so that any gasser tach can be used. It costs US$65 and can be seen
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=128/category_id=311/home_id=59/mode=prod/prd128.htm
Aftermarket diesel tachs run from an inductive pickup strapped around the alternator, usually. Autometer is the only brand I can find and the gauge is just 3.5" diameter. Of course, you could pull the 5" tach from a scrap GM HD truck but how these connect, where you had no tach before, I don't know.
Then there's the LCD digital 'TinyTach' - which has a pickup around an injection line for sensing - but I don't think it would look as good. and is a 3" x2" rectangle.
BTW - did you ever see these links?
http://www.73-87.com/7387garage/interior/gauges_recessed.htm
http://www.73-87.com/7387garage/interior/gauge_surface.htm
Let us know what happened!
« Last Edit: April 19, 2009, 09:58:49 pm by AdrianR »
Chevy lover
1985 Suburban K10 Silverado diesel
Re: 6.2 L Diesel
« Reply #4 on: April 20, 2009, 07:38:28 am »
Adrian,
It will be a while before I can get to this point so I will cross that bridge when I get there.  There is a specific set that I want for my truck and I have seen the post on recessed and surface mouting the guages.  I will be doing the recessed when I get to that point.  Thanks for the like to the adapter.  I think that might be my best bet...maybe...if I don't find a better option.
Levis
Levis
Offline hatzie
Re: 6.2 L Diesel
« Reply #5 on: May 24, 2009, 08:12:14 am »
Levis
Bringing this thread back from the dead...  You may want to check out The Dieselpage.  Lee Swanger came up with a relatively simple circuit to drive a gas engine tach off the ESS sensor on the 6.2 vacuum pump.
Adrian,
Levis
Re: 6.2 L Diesel
« Reply #6 on: May 26, 2009, 08:49:03 am »
Thanks hatzie
Levis
Offline AdrianR
Re: 6.2 L Diesel
« Reply #7 on: May 26, 2009, 06:49:55 pm »
Problem is, that's a 'pay per view' part of the site for paid members only...anyone have the article they can PM me?
Thanks
Chevy lover
