Author Topic: fiberglass hood  (Read 6230 times)
Offline 808SS
fiberglass hood
« on: March 06, 2009, 01:15:39 pm »
Just need alittle help, the hood came with the truck but I notice when I open the hood the springs are gone so I have to hold the hood up with a stick. Is there a reason not to use the springs with the fiberglass hood?
1979 C10, airride, 20" rims, and lots of rust
1994 Impala SS, under construction, LSX, 4L80E, 4.10 gears, sound system, 20" rims up front and 22" rims rear
Re: fiberglass hood
« Reply #1 on: March 06, 2009, 01:22:54 pm »
Most are too flimsy to handle compressing the springs. I plan on putting the little hydraulic shocks used on newer cars and hatchbacks to hold mine up. For now, just a prop rod.
Offline 808SS
Re: fiberglass hood
« Reply #2 on: March 06, 2009, 02:17:37 pm »
I was thinking that was the problem just need to hear it from someone else. let me know about that little hydraulic shock
Thanks guys
Re: fiberglass hood
« Reply #3 on: March 06, 2009, 03:39:45 pm »
you need low tension springs or a prop rod. Just another reason why fiberglass is a pita. What year is your truck?
Offline cubicdollars
Re: fiberglass hood
« Reply #4 on: March 06, 2009, 03:40:26 pm »
What I have seen people do in the past is drill a hole through both sides of the hing while the springs are still attached then remove the springs. When you raise the hood you then place a pin or bolt through the hole. So much easier and safer than dragging a prop rod around.
Hope this helps
Offline 808SS
Re: fiberglass hood
« Reply #5 on: March 06, 2009, 05:15:05 pm »
79' any idea or part# for the low tension spring?
Re: fiberglass hood
« Reply #6 on: March 06, 2009, 05:22:08 pm »
