Author Topic: 1985 K5 Blazer: Added another one to the stable  (Read 177046 times)
Offline DnStClr
Re: Added another one to the stable
« Reply #15 on: March 12, 2009, 08:26:41 am »
If it was me I would put a 6.5 diesel in it. Glad to see you're gonna be one of us oil burner freaks.. ;D
Don
87 Chevy Silverado
Offline 80stepsideguy
« Reply #16 on: March 12, 2009, 12:36:33 pm »
Chris,
great score man, the deals are out there people.I would but i got to much time invested into the 80 to get another project at this time. Maybe once the truck is in paint and running. ;D
thanks
pat
1998 Chevy 1500 S/B 2wd
« Reply #17 on: March 12, 2009, 06:00:53 pm »
Yeah, I am looking for either a 6.2L or 6.5L, so either would do....
« Reply #18 on: April 20, 2009, 04:40:19 pm »
FYI, I just picked up the CUCV 6.2L diesel for this along with the complete wiring harness.  I also ordered the floor pans for it and the Jimmy.
Re: 1985 K5 Blazer: Added another one to the stable
« Reply #19 on: June 13, 2009, 10:06:43 am »
Saturday, March 15th, 2009: pulled the front seats and carpet out to access the rust damage
Saturday, June 6th, 2009: replaced the rear window track rollers, gutted the complete interior to find all the rusted area.  Found out the rear power motor only works going down now....
Sunday, June 7th, 2009: In talks with acquiring a used banks turbo kit.  Waiting for the total for shipping.
Friday, June 12th, 2009:Picked up a power window motor and replaced it only to find the battery completely DEAD so it is on charge now.
« Reply #20 on: June 25, 2009, 12:51:14 pm »
Saturday June 13th, 2009: Battery charged and new motor still only goes down not up.  had to manually roll it up for troubleshooting later.
Saturday June 22nd, 2009: Sent payment for the Banks Sidewinder kit.
« Reply #21 on: November 29, 2010, 03:39:46 pm »
Got back on this during Thanksgiving vacation after a long hiatus
Friday, Nov 26th, 2010:Started pulling parts to get the 350 out, pulled the A/C, Power Steering, wiring, hoses and radiator.
Saturday, Nov 27th, 2010:removed the exhaust, trans inspection plate, braces, and t-case brace and torque converter bolts.
Sunday, Nov 28th, 2010:Supported the trans, disconnected the supply/return fuel hoses, pulled out the hoist and found it wouldn't go up high enough, so I pulled the valve cores out to get the motor free.  As of last night the 350 is out.
Monday, Nov 29th, 2010:Sourcing a new converter, 12V starter so I can drop the 6.2L in.  Hope to get it cleaned up and see if it needs new gaskets this week/weekend.
Offline BlueCollarRon
« Reply #22 on: December 03, 2010, 01:55:02 am »
right on 6.2 with a turbo.. last one I seen they had to notch the frame. wheres the pictures?
« Reply #23 on: December 13, 2010, 12:09:17 am »
Thursday, Dec 2nd, 2010:Got a new diesel converter
Saturday, Dec 11th, 2010:moved the 6.2L to the house and started cleaning it up.  Ran out of daylight.  Looks like I need to replace at least the valvecover gasket on the passenger side.
« Reply #24 on: January 31, 2011, 10:31:18 pm »
Sunday, Jan 30th, 2011: Got the 6.2L dropped back in the truck yesterday evening.  Still have top 2 bolts in the Trans to bolt up, along with starter.
Anyone got some tips on retro-ing the wiring harness on this thing.  I actually have most of the donor wiring harness but if anyone has done this before I would love some feedback.  I hate wiring...
« Last Edit: April 14, 2011, 12:02:50 am by Captkaos »
« Reply #25 on: July 25, 2011, 11:42:00 pm »
February 11, 2011: Vile sent me some AC Diesel brackets for the truck to be tolerable in the heat.
Also purchased a drivers side Battery box sometime this summer from GM.
« Last Edit: October 23, 2011, 08:14:06 pm by Captkaos »
« Reply #26 on: October 23, 2011, 08:12:24 pm »
Oct 22, 2011: Sometime in the past I put the starter on but neglected putting the engine bolts on.  So today I pulled the started BACK off and put the bolts in and then put the starter back on.
I also pulled the Gasser harness out and I am currently verifying that the CUCV harness I got from the 6.2L donor will work with the the 1985 harness.  I still need to remove the 24V circuits, but hopefully I can make what I have work with little modifications.  So far it looks ok, but I really would like a Civilian harness diagram to compare what I have to.
CUCV on the top above broom handle, Gas below...
In addition I started figuring out how the AC hooks up.  I found how the Brackets Vile sent work, but it appears I need another bracket that goes to the front of the head as mine has the povision for the second alternator.  Anyone have pics on this?  Vile, do you happen to have the other bracket?
I am confident that the wide bracket bolts to the intake on the 2 studs pictured, and the lower bracket got to the exhaust, but the front I don't have.
« Reply #27 on: October 23, 2011, 09:37:41 pm »
I know I posted pix of the bracket set up in another thread for someone. It was a while back. I'll see what I can find.
« Reply #28 on: October 23, 2011, 09:41:23 pm »
can't find it. It was scanned out of one of my manuals....
« Reply #29 on: October 23, 2011, 09:52:49 pm »
you don't happen to have the other bracket for the front of the head do you?
