Author Topic: 1985 K5 Blazer: Added another one to the stable  (Read 175453 times)
Re: 1985 K5 Blazer: Added another one to the stable
« Reply #45 on: November 06, 2011, 10:36:18 am »
Saturday, Nov 5th, 2011: Sorted out all the wiring on the Diesel Harness, pulled some connectors from the internal harness and plan to splice them into the existing gasser harness (Water in Fuel circuits)
Offline junkman.
« Reply #46 on: November 07, 2011, 12:21:56 am »
I found these on ebay:
http://www.ebay.com/itm/1984-Chevrolet-6-2-Diesel-AC-Bracket-Set-/200662856915?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2eb87034d3
search E bay 1984 Chevrolet 6.2 diesel  AC brackets  full set $100.00
i don't know how to insert the link or it won't let me
« Last Edit: November 07, 2011, 07:59:47 am by Captkaos »
« Reply #47 on: November 07, 2011, 08:17:00 am »
Sunday, Nov 6th, 2011: I got all of the wiring in the Diesel harness sorted out and removed what I didn't need from it; secondary Alternator, and assorted wiring, TH400 plug/wiring.
Repaired the Temp sending from the Gasser harness, spliced the long side Alternator to the main circuit wire to match the gasser.
Removed the Water in Fuel light harness from the bulkhead along with the grounding for the Wait Light.
Now I just need to loom it up with the Glow control wiring and mount the Glow relay and the Filter Assembly.  AND find a throttle cable and figure out how the 700R4 TV connects and get that for it.
Offline thirsty
    • Suitor's Garage
« Reply #48 on: November 07, 2011, 10:28:41 am »
A lot of homework goes along with this build, more than just nuts and bolts. Good job on the tedious and unknown stuff Capt.
« Reply #49 on: November 07, 2011, 12:14:25 pm »
I am trying to document it all just in case there is a next time.
« Reply #50 on: November 12, 2011, 11:03:12 am »
Friday, Oct 11, 2011: picked up a throttle cable for the truck, traded to a guy that wanted the gasser.
Still looking for a TV cable bracket.
« Reply #51 on: November 21, 2011, 01:33:20 pm »
Ok, this this is about to to be a Gasser again..  I can't find the TV cable bracket that goes with the Diesel (PN 14038643) and without it I can't drive this thing.
If I can't find it in the next day or so the TBI that came out of the 89 is going into this one..
« Reply #52 on: November 21, 2011, 04:09:10 pm »
Jamie from http://www.dieseldepot.com/ called me today and he has the brackets I need to get this thing going.
Offline junkman.
« Reply #53 on: November 29, 2011, 12:53:27 am »
that's good news I'd bet there getting hard to find
also did you ever get your A/C bracket
« Last Edit: November 29, 2011, 12:57:15 am by junkman. »
« Reply #54 on: November 29, 2011, 10:59:49 pm »
I thought I was getting an AC mount from Jamie.  Everything came today and it is the wrong one.  Plus I think I have to get a power steering pump without the reservior.
Offline heavychevy91
  • '86 Chevy K20
« Reply #55 on: November 30, 2011, 02:32:04 pm »
For the A/C mounts i was at the local pick and pull last Saturday and found a 1990 Suburban with the 6.2 and A/C. Someone had already pulled the trans iirc it had a TH400 though. Ill be going back this Saturday to get the clearance lights and harness if you need anything. I Took a few pic of it and have them on my computer at home if you need.
Offline junkman.
« Reply #56 on: December 08, 2011, 12:44:26 am »
did pull your parts pan out
power steering pump and remote reservoir that's what's om mine
« Reply #57 on: December 12, 2011, 05:40:27 pm »
Saturday, Dec 3rd, 2011: After receiving a new open plenum intake, valve cover and fill tube, TV bracket and 85-93 Glow controller, started the disassembly of the topend.  Got the intake and valve cover removed.  Cleaned it up and installed the new TV bracket, glow controller and then put the valve cover on before it got too dark.
« Last Edit: December 12, 2011, 05:52:31 pm by Captkaos »
« Reply #58 on: December 12, 2011, 05:49:21 pm »
Saturday, Dec 10th, 2011: put the new intake on with associated parts.  Removed the power steering assembly to verify the mounting for the AC pump brackets.  Found they didn't work.  Need to find a remote reservoir for the existing pump to go with the Hydroboost I am installing.
« Reply #59 on: December 12, 2011, 05:52:14 pm »
Sunday, Dec 11th, 2011: Pulled the Vacuum booster assembly off the truck, mocked up the Hydroboost assembly.
Monday, Dec 12th, 2011: Talked to Diesel Depot and he found a truck with the brackets I need.  Hopefully will be getting them next weekend.
