Author Topic: Rocker draggin' 83  (Read 11415 times)
Offline ndametz32
Rocker draggin' 83
« on: May 25, 2009, 08:38:42 pm »
Ok, I don't know very much.. make that anything about suspension setups in these trucks. I want to slam my '83 stepside on the ground but i have no idea where to start. im assuming i'll need to bag it, put in a shorter rear end and what not. but if anyone could give me detailed instrucions or steps on how they did this or just how to do it, it would be greatly appreciated! thanks alot
nick
'83 Chevy Silverado Stepside
Re: Rocker draggin' 83
« Reply #1 on: May 25, 2009, 08:49:44 pm »
Well if you want it draggin on the ground I would bag it so you can actually drive it. You'll have to do some serious hacking though.
Offline ndametz32
« Reply #2 on: May 25, 2009, 08:54:08 pm »
thats what i was afraid of  :-\
Offline N2TRUX
« Reply #3 on: May 26, 2009, 07:52:43 am »
It really depends on exactly how low you want to go. Keep in mind the A-arms will touch the ground before the frame or rockers do.
I suggest you go with a static drop to get started, and educate yourself on air suspension to determine if it's what you really want.
Offline ndametz32
« Reply #4 on: May 26, 2009, 10:50:24 am »
Here's an 83 C-10 stepside (same year/body style as my truck) and this is the exact height I want my truck. I know my truck was lowered slightly by the previous owner but I'm not sure how much.
« Last Edit: May 26, 2009, 10:55:47 am by ndametz32 »
« Reply #5 on: May 26, 2009, 11:18:33 am »
Dropmember is the fastest route to getting one like pictured above.
This truck has a Porterbuilt setup in it:
May want to check this thread out also:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11763.0
Offline ndametz32
« Reply #6 on: May 26, 2009, 11:35:49 am »
So would I still have to bag it to get it as low as the truck you posted above?
Offline 80stepsideguy
« Reply #7 on: May 26, 2009, 11:38:28 am »
Yeah i believe you would have to to get it that low.A regular suspension wont get you that low I.E leaf springs and coils.
thanks
pat
« Last Edit: May 26, 2009, 12:19:56 pm by 80stepsideguy »
1998 Chevy 1500 S/B 2wd
Offline ndametz32
« Reply #8 on: May 26, 2009, 11:42:03 am »
Can I get my truck any lower than it already is without bagging it?
« Reply #9 on: May 26, 2009, 11:58:22 am »
No you don't, as far as I know you can have Nathan setup the Dropmember for springs, you can call Porterbuilt to verify.
Bags will add adjustability.
Offline ndametz32
« Reply #10 on: May 26, 2009, 12:49:21 pm »
Alright man thanks for your help!
