Author Topic: Have to Slam the doors to get them to close  (Read 41176 times)
Offline pontgta
« on: April 07, 2010, 05:08:05 pm »
I have to slam the door to get it them to close(dirvers and pass). Doors look aligned correctly, and i have never touched them. The hinges look good and feel good because i did the " pull up on the the door edge" and the whole truck moves not just the door.
I have tried to adjust the striker, but seem to have no adjustmnet.
Looks like the striker need to be pushed outwards towards the door, so when i push i  will not have to slam it. The door latch seems to latch fine if i understand it correctly.  Striker press on "catches the door" then a liitle movemnet foward and it should catch completly and  complete close.  The end portion is what i am having probelms with getiing them to completely close without force.
In suggestion would be very helpful
Thanks
Offline Layne
Re: Have to Slam the doors to get them to close
« Reply #1 on: April 07, 2010, 05:20:13 pm »
How's your weatherstripping? I got new on both doors, and I really gotta muscle the door shut.
« Reply #2 on: April 07, 2010, 08:40:09 pm »
Are the bushings on the striker.
« Reply #3 on: April 07, 2010, 09:06:04 pm »
What do you mean the striker has no adjustment? You just loosen it and move it. I usually leave it slightly loose and latch the door. Then I open it carefully and tighten it. That gives you a good starting point.
Offline pontgta
« Reply #4 on: April 07, 2010, 10:37:36 pm »
Thanks for all the responses
The weatherstripping looks good, but might be the original. I have not replaced any weatherstriping.
Got the truck this way with the doors shutting this way
I will have to try to adjust the strikers again, but last time i tried they moved, but it was less than 1/16 of an inch.
Are they suppose to have busshing?  What do they look like?
« Reply #5 on: April 07, 2010, 10:42:04 pm »
Offline pontgta
« Reply #6 on: April 07, 2010, 10:48:52 pm »
Can i buy just the busshing,or do i have to buy the whole thing?   I know they can't be much? Where can i buy them?
Offline pontgta
« Reply #8 on: April 08, 2010, 01:52:59 pm »
OOOH YEAH!  Just went to Advance and pickup the striker bolts(did not have the bushings). I took the bushings off the new striker, and put them on my old striker(i like to keep it as original as i can and striker was in good shape). Intalled the striker with new bushings, and ahhh i do not have to slam the door  any more.  Closes with little to no effort.
Oh , the reason i thought they had no adjusment was beacuse i had loosened them up and on of the washers was stuck on and did not move, so i stand corrected they can be adjusted
Thanks for all the help.
Offline Stephanos
  • My life: Work + College – Social Time = Boring
« Reply #9 on: April 08, 2010, 04:15:10 pm »
I have to use some force to close the doors (both driver and passenger) on mine, but if I crack the window(s), they close easily with no effort. I was told the cab is "tight" and the air inside the cab is being compressed.  :-\  Somehow I doubt that.
1987 Chevrolet V-10 Fleetside
« Reply #10 on: April 08, 2010, 05:36:40 pm »
Stephanos,
Check the vent flap at the bottom of your door, see if it is stuck.  It should be free to move out to release the pressure.
Offline eventhorizon66
« Reply #11 on: April 16, 2010, 01:50:35 pm »
I meant to report on this last night but forgot.
I put sleeves on my striker bolts last night and all I can say is wow.  I wish I had done it sooner.  The passenger door immediately started shutting like a late model.  The driver door showed that it required some striker bolt adjustment as it was quickly cutting a groove in the new sleeve.  After the adjustment, I can open my door just 4 inches and shut it with my index finger.  As an added bonus, this has taken care of a few of my door rattles. 8)
'85 C10 SWB 350 700R4 TKO600
Offline 1980c10
« Reply #12 on: April 18, 2010, 11:57:06 pm »
I also replaced my door strikers yesterday and what a difference. thanks for the tip.
Offline Armor
« Reply #13 on: April 27, 2010, 06:48:23 pm »
why does it close easier when the bushing is there? i would of thought that a larger pivot would be harder. i gotta get some bushings now lol.
Offline mrboyy17
« Reply #14 on: April 27, 2010, 07:27:45 pm »
i just used this pex piping trick you guys suggested.....works perfect and i got a 5 ft stick for 1.73 at lowes.  thanks for the tips guys it really worked great
