Body, Glass & Paint
Have to Slam the doors to get them to close
Topic: Have to Slam the doors to get them to close (Read 41179 times)
pontgta
April 07, 2010, 05:08:05 pm »
I have to slam the door to get it them to close(dirvers and pass). Doors look aligned correctly, and i have never touched them. The hinges look good and feel good because i did the " pull up on the the door edge" and the whole truck moves not just the door.
I have tried to adjust the striker, but seem to have no adjustmnet.
Looks like the striker need to be pushed outwards towards the door, so when i push i will not have to slam it. The door latch seems to latch fine if i understand it correctly. Striker press on "catches the door" then a liitle movemnet foward and it should catch completly and complete close. The end portion is what i am having probelms with getiing them to completely close without force.
In suggestion would be very helpful
Thanks
Layne
Re: Have to Slam the doors to get them to close
April 07, 2010, 05:20:13 pm »
How's your weatherstripping? I got new on both doors, and I really gotta muscle the door shut.
April 07, 2010, 08:40:09 pm »
Are the bushings on the striker.
April 07, 2010, 09:06:04 pm »
What do you mean the striker has no adjustment? You just loosen it and move it. I usually leave it slightly loose and latch the door. Then I open it carefully and tighten it. That gives you a good starting point.
pontgta
April 07, 2010, 10:37:36 pm »
Thanks for all the responses
The weatherstripping looks good, but might be the original. I have not replaced any weatherstriping.
Got the truck this way with the doors shutting this way
I will have to try to adjust the strikers again, but last time i tried they moved, but it was less than 1/16 of an inch.
Are they suppose to have busshing? What do they look like?
April 07, 2010, 10:42:04 pm »
pontgta
April 07, 2010, 10:48:52 pm »
Can i buy just the busshing,or do i have to buy the whole thing? I know they can't be much? Where can i buy them?
April 08, 2010, 12:08:53 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=15395.0
pontgta
April 08, 2010, 01:52:59 pm »
OOOH YEAH! Just went to Advance and pickup the striker bolts(did not have the bushings). I took the bushings off the new striker, and put them on my old striker(i like to keep it as original as i can and striker was in good shape). Intalled the striker with new bushings, and ahhh i do not have to slam the door any more. Closes with little to no effort.
Oh , the reason i thought they had no adjusment was beacuse i had loosened them up and on of the washers was stuck on and did not move, so i stand corrected they can be adjusted
Thanks for all the help.
Stephanos
My life: Work + College – Social Time = Boring
April 08, 2010, 04:15:10 pm »
I have to use some force to close the doors (both driver and passenger) on mine, but if I crack the window(s), they close easily with no effort. I was told the cab is "tight" and the air inside the cab is being compressed.
Somehow I doubt that.
1987 Chevrolet V-10 Fleetside
April 08, 2010, 05:36:40 pm »
Stephanos,
Check the vent flap at the bottom of your door, see if it is stuck. It should be free to move out to release the pressure.
eventhorizon66
April 16, 2010, 01:50:35 pm »
I meant to report on this last night but forgot.
I put sleeves on my striker bolts last night and all I can say is wow. I wish I had done it sooner. The passenger door immediately started shutting like a late model. The driver door showed that it required some striker bolt adjustment as it was quickly cutting a groove in the new sleeve. After the adjustment, I can open my door just 4 inches and shut it with my index finger. As an added bonus, this has taken care of a few of my door rattles.
'85 C10 SWB 350
700R4
TKO600
1980c10
April 18, 2010, 11:57:06 pm »
I also replaced my door strikers yesterday and what a difference. thanks for the tip.
Armor
April 27, 2010, 06:48:23 pm »
why does it close easier when the bushing is there? i would of thought that a larger pivot would be harder. i gotta get some bushings now lol.
mrboyy17
April 27, 2010, 07:27:45 pm »
i just used this pex piping trick you guys suggested.....works perfect and i got a 5 ft stick for 1.73 at lowes. thanks for the tips guys it really worked great
Body, Glass & Paint
