Author Topic: Need some help with my 87 Burb  (Read 12292 times)
Offline Redcell
« on: May 01, 2010, 09:45:56 pm »
Hi all. Glad I found the board. I have a 87 Burb I am unsure of the model How can I tell? It runs great, ac works, and all windows work except the tailgate window. I try to open it via the button on the dash and key at the back and hear nothing. The window is up now any way to get it down without breaking the glass? Also was trying to find a way into the tailgate but could not find anyway in. I did not want to break anything so kind of left it to come check on the web. Any help would be great and again glad to be part of the forum.
Re: Need some help with my 87 Burb
« Reply #1 on: May 01, 2010, 10:43:32 pm »
Pull the interior access panel off the gate and find the power motor, remove the cable from the motor, hook a cordless drill and chuck the cable in it and put it on reverse.
The glass HAS to be down to open the gate.
Offline Redcell
« Reply #2 on: May 01, 2010, 11:09:55 pm »
Hi and thank you for your quick reply. I do not see an access panel. Just the plastic and carpet over it I tried to pull the plastic off but ti would not budge. Where is this interior access panel at? have a picture?
« Reply #3 on: May 01, 2010, 11:20:36 pm »
I don't have a picture, the plastic bolts to the gate, the access is behind it.
Offline Redcell
« Reply #4 on: May 01, 2010, 11:49:39 pm »
So how do I pull the plastic cover off? Here is a picture of what im talking about.
Offline Redcell
« Reply #5 on: May 02, 2010, 12:50:53 pm »
Thank you I found it. Dose anyone know where a fuse layout online is. I need to check the fuses.
« Reply #6 on: May 02, 2010, 02:09:58 pm »
What's your VIN#?
Offline Redcell
« Reply #7 on: May 02, 2010, 02:27:36 pm »
vin # is 1gnev16k6hf166836 And thank you for the layout.
« Reply #8 on: May 02, 2010, 03:58:09 pm »
1987 Chevrolet Suburban 4WD 1/2 ton (V10) TBI 350
Offline Redcell
« Reply #9 on: May 02, 2010, 08:45:15 pm »
Thank you guys I took it apart and put it back and its works great now. Thank you.
« Reply #10 on: May 03, 2010, 10:43:03 am »
missed this over the weekend Redcell.  Glad you got it together.
