73-87 Chevy & GMC Trucks
Finally got my first 86!
4
5
7
Topic: Finally got my first 86! (Read 71106 times)
Swims350
Re: Finally got my first 86!
Reply #30 on:
July 17, 2010, 10:21:55 pm »
correct me if I'm wrong but that's exactly where the 5.0lg came from and if so then no it's on over towards the middle or on the pass. side, older blocks where right as mentioned behind the head first flat, newer ones are more in the middle as mine is in the 88.
www.cardomain.com/id/benwa454
86gmc23
Reply #31 on:
July 17, 2010, 10:30:28 pm »
Yes it was at the very end of the drivers side head.
Swims350
Reply #32 on:
July 18, 2010, 09:14:05 am »
the casting will be above that, or on the other side and up higher then the 5.0 thing. By higher up I mean closer to the point of the bellhousing.
86gmc23
Reply #33 on:
July 18, 2010, 10:52:02 am »
Will have info posted later today on it.
Are these heads good for a 305 or 350?
#3998991
Swims350
Reply #34 on:
July 18, 2010, 01:16:30 pm »
3998991 307/350 68-79 1.72/1.50 76cc
wow never seen a set like that, small valves with a big cc size. My 2.02 valved heads are 76cc. I think they are kinda small on the 1.72 valve size but then again they came on 307's and 350's so they'd be ok I'd think at least as far as stock goes. Not sure how the small valve size would effect performance.
86gmc23
Reply #35 on:
July 18, 2010, 01:43:15 pm »
They are just for sale in my area for $50. Im not going to look for anymore parts for this motor, just put it up for sale and when/if it sells start looking for a 350.
oldwhity
Reply #36 on:
July 18, 2010, 04:35:00 pm »
Swims, I was only going off of what I read. Now you got me doubting lol. I going out to look at the one that I just pulled.
86, I wouldn't get rid off all that yet. You'll always need it after you get rid of it. It just works that way.lol
Rob G.
81 Chevy K20 4x4 LWB stepside
oldwhity
Reply #37 on:
July 18, 2010, 04:53:13 pm »
Swims, Your right! The other numbers are there. Thanks
86, they should be in the same location just on the passenger side near the center.
In this pic I'm pointing to it with a brush.
Right behind/below the distributor.
Hope this helps.
Rob G.
Swims350
Reply #38 on:
July 18, 2010, 05:08:11 pm »
It's ok oldwhity, I knew they were there, but I'm glad you cleared up which side it was driving me nuts. Now I know it's pass top flat near the peak.
btw oldwhty is awesome, that's what we called the old 76 we had, it holds alot of sentimental value with me and when I read your screenname it brought back memories.
and for posting here's the info I got...
14088548 350 86-88 155-195 2-bolt Truck Passenger stick 1-piece seal
Last Edit: July 18, 2010, 05:09:49 pm by Swims350
oldwhity
Reply #39 on:
July 18, 2010, 05:34:28 pm »
Thanks, I have a binder of casting number printed from the web from a few year back. Your info seems to be a little more specific or detailed. Mine showed 1986-94 350. It had dashes for the hp, main caps, and body it came in. I wouldv'e thought it would be a 4bolt main since it was in a k30. Oh well, I'll check it out later.
Oldwhity popped up when I got my k20. I guess it stuck in my head from when my dad had his white 79'. He called it the same thing.
Rob G.
Swims350
Reply #40 on:
July 18, 2010, 06:47:36 pm »
every site has different info on casting numbers.
yea same here my old man called the 76 old whitey and now his 84 is the same, it's white and has the same 350 in it lol.
86gmc23
Reply #41 on:
July 18, 2010, 10:26:05 pm »
Is there a site you prefer for casting numbers? Figure when I start going to junk yards it may be a good idea to make a binder like Oldwhity said he had.
Swims350
Reply #42 on:
July 19, 2010, 09:30:58 am »
yes sir, it's the one I been using chevymania.com then you click on parts id
Jims86tpisub
Reply #43 on:
July 20, 2010, 01:42:57 pm »
looks like the trans is a th-350
Jim
1986 K10 Suburban
Tuned Port Injection
193 Heads
Comp 260H cam
700r4 Raptor
Single exhaust with 2 Magnaflow Mufflers inline
Swims350
Reply #44 on:
July 20, 2010, 02:22:17 pm »
huh? what about the trans being a th350? you talking about in his or yours? An 86 shouldn't have a th350, I think by 86 and up it was all 700r4's or at least a th350c.
4
5
7
