one header tube glowing red?!?
Topic: one header tube glowing red?!? (Read 16152 times)
4x4orbust
January 20, 2011, 05:58:44 pm »
i was checking fluids on the truck before another snow storm tonight (Yesssir!) and noticed that one of my header tubes was glowing red. the #6 cylinder, and it is the only one doing it. there is a spot at the head that doesnt glow (bout an inch) and then 6 or so inches are glowing. not bright red, but a noticeable glow.
I checked spark and it was fine. i know the carb needs to be rebuilt, but if it was carb related, why only one cylinder? maybe a sticking valve, or retarded timing?
i'm lost
any ideas what would cause this?
1982 chevy K-10 SWB, 355 th350/np208. 2.5"lift, 33" swampers, headers/duals, current project
Grim 82
Re: one header tube glowing red?!?
January 20, 2011, 06:23:57 pm »
What does that spark plug look like?
Most likely it's in the valvetrain. Loose rocker, bent pushrod, flat spot on the cam, it's hard to say. I doubt it's your carb though, or it would affect more than just one cylinder.
January 20, 2011, 07:54:37 pm »
Do a compression test on that cylinder
4x4orbust
January 21, 2011, 04:19:38 pm »
i did a compression test on the cylinder. it's at 110. here is the spark plug from #6
i pulled the plug on #4 as well and checked that one. same, at 110. plug from #4
4x4orbust
January 22, 2011, 03:51:39 pm »
any ideas? i'm not sure where to even start looking
ohio hab
1984 C-10, 383 SBC
January 22, 2011, 05:33:03 pm »
Usually caused from timing to retarded, or too rich fuel mixture so the fuel is burning in the header. I would check for a bad spark plug, wire, since only in one cylinder. Make sure getting full spark to that cylinder. I since re read your post and you checked the spark, also could be a bad cam lobe. Check timing first.
Last Edit: January 22, 2011, 05:38:09 pm by ohio hab
January 22, 2011, 05:36:28 pm »
Couple things come to mind. One you need some lotion lol. Two how old the plugs. Three did you check the compression on the other cylinders
4x4orbust
January 22, 2011, 06:49:33 pm »
timing is set at 8*, set it about 2 months ago, and thats where it ran best. plug wires are good, thats what i was checking when i found the glowing tube.
i'll have to get my girl to look into some lotion. shes always haggling me about my working man hands. the spark plugs were replaced last winter. i will be checking the other cylinders tom for compression.
Last Edit: January 23, 2011, 03:32:04 pm by 4x4orbust
January 22, 2011, 11:39:42 pm »
Some times working with metal if it’s thin, rusty or has resistance it will get hotter than a thicker or clean surface. That could explain the tube but for the plug idk. About the lotion lol my wife is in charge of that, I can’t remember what type it is but it works well
January 23, 2011, 09:57:26 am »
Did you check for vacuum leaks? Do you have a cylinder leakage gauge? What thermostat are you running? What # spark plugs do you have?
4x4orbust
January 23, 2011, 01:57:21 pm »
i found one vac. leak, inside the cab somewhere. I disconnected the hose running into the cab and capped it off. (not sure what it even does?!)
i do not have a cylinder leak kit, but am trying to find one locally. i am running a 180* thermostat. not sure on the # spark plugs, i know they are champions though.
edit: also figured out i don't know how to check compression, so those numbers are not accurate. will try to do it the right way tom.
Last Edit: January 23, 2011, 03:32:14 pm by 4x4orbust
Grim 82
January 23, 2011, 03:10:43 pm »
The hose running into the cab is for the HVAC system, controlling the direction of air flow for the floor, defrost, etc.
It could also be an intake leak right by that cylinder.
beastie_3
Josh
January 23, 2011, 04:24:43 pm »
It puts the lotion on its skin...
Semper Fi
January 23, 2011, 04:27:48 pm »
lol
January 23, 2011, 11:51:21 pm »
Lmao
