Author Topic: Engine Confusion  (Read 4681 times)
Offline 78chevyshortbed
Engine Confusion
« on: December 12, 2012, 03:19:29 pm »
on my motor it is stamped as a GM 14010207 and CFD 207. anybody have any knowledge towards this. Need help on whether its a 350 or 305. i did research and the GM 14010207 states that it is a 350. but the CFD 207 states that the motor is a 305. Help?
Re: Engine Confusion
« Reply #1 on: December 12, 2012, 06:11:59 pm »
     Where are you getting the info that says its a 305 ?
« Reply #2 on: December 12, 2012, 06:30:22 pm »
I researched the CFD 207 and it says it's a 305.
« Reply #3 on: December 12, 2012, 06:32:11 pm »
350
« Reply #4 on: December 12, 2012, 06:34:30 pm »
Now all I'm seeing while I'm researching is that it's a 350.
« Reply #5 on: December 12, 2012, 07:01:30 pm »
okay, if you go on nastyz28.com and click the link thing that says, QUICKLY IDENTIFY A CHEVY ENGINE CLICK HERE, and go to the suffix codes and fine CFD and it says its a 305. if i go on this sight actually, just 73-87.com and go to engine identification and find the GM 14010207 it says its a 350???
« Last Edit: December 12, 2012, 07:07:25 pm by 78chevyshortbed »
« Reply #6 on: December 12, 2012, 11:09:57 pm »
     Are both of these numbers stamped on the engine ?  Not the head, and where are you finding the numbers Exactly on the engine ?
     Behind the drivers side below the head on the block is where you should be looking.
« Reply #7 on: December 13, 2012, 12:48:06 pm »
You cannot go by the suffix code, it is a 350.  Engine casting number trumps whatever is on the machined pad.  Is the Engine code stamped there?
