Author Topic: Still no blower motor updated pics  (Read 46656 times)
Re: Still no blower motor updated pics
« Reply #45 on: December 04, 2013, 07:00:41 pm »
Connect these two wires. Why did you disconnect it?
Offline darmentle
« Reply #46 on: December 04, 2013, 07:03:33 pm »
ok let me connect them together ? don't have the thermostatic switch hooked up ac has been deleted.
« Reply #47 on: December 04, 2013, 07:10:50 pm »
You're trying to be your own worst enemy aren't you?   :P lol
Offline darmentle
« Reply #48 on: December 04, 2013, 07:15:42 pm »
i hooked the two green wires to each other nothing . Does the heater need the thermostatic switch hooked up in order to work. Also with my test light hooked up to B+ i touched the positive connection on the blower and did not here it spin up, so i checked the grounds i have and they are good. maybe a faulty blower ?
« Reply #49 on: December 04, 2013, 07:28:57 pm »
Leave them connected and yes they need to be hooked up but for now just leave them connected. Your test light will not power up your blower motor, You would need to make a direct connection to test the motor but the problem you are having is no B+ at the purple wire and the little orange wire according to your test so stay on task. You need to check at the switch as mentioned above
Offline darmentle
« Reply #50 on: December 04, 2013, 07:43:25 pm »
i have power at the purple wire now. is there suppose to be power at the small orange wire at the relay?
« Reply #51 on: December 04, 2013, 07:47:08 pm »
OK so is the fan working now?
Offline darmentle
« Reply #52 on: December 04, 2013, 08:05:22 pm »
no when i hook up the purple wire to the blower box i lose bower to the purple  wire. its driving me crazy
« Reply #53 on: December 04, 2013, 08:30:43 pm »
With your fan switch on high koeo in the vent position you have B+ at the little Orange wire at the relay Y or N?
Offline darmentle
« Reply #54 on: December 04, 2013, 08:35:55 pm »
no
« Reply #55 on: December 04, 2013, 08:55:44 pm »
OK, If you reconnect everything with the key on, blower on high and run a jumper wire to the small orange wire at the relay and touch the Battery positive post does anything happen? (use a jumper wire not your test light)
Offline darmentle
« Reply #56 on: December 04, 2013, 09:00:55 pm »
i will check tomorrow when i get off . if haven't pulled my hair out by then. lol
Offline darmentle
« Reply #57 on: December 05, 2013, 05:25:12 pm »
ok now it has a mind of its own .
At the relay
Key off
Big Orange wire Hot
Small orange wire no power
Purple wire no power
With the key on
Big orange wire has power
Small Orange wire has power
Purple wire has power
So i go to do your test with everything hooked up turn the key to on and pop goes the in line fuse. so now when the purple wire is hooked up to the blower its blowing that inline fuse.
« Reply #58 on: December 05, 2013, 06:50:28 pm »
OK so take a jumper wire (fused preferably) and energize the blower motor directly from the battery. Does the blower motor run?
Offline darmentle
« Reply #59 on: December 05, 2013, 06:59:00 pm »
nothing  looks like that one is faulty. shot out some sparks haha im awake now
