Author Topic: Still no blower motor updated pics  (Read 46614 times)
Offline darmentle
Re: Still no blower motor updated pics
« Reply #30 on: December 03, 2013, 07:42:20 pm »
ill be wax on wax off be right back
Offline darmentle
« Reply #31 on: December 03, 2013, 08:27:21 pm »
ok so i got power going threw the fuse and i now have power at the purple wire going to the blower. but as soon as i turn on the key i loose power to that purple wire going to the blower . now if i unplug the purple wire to the blower and turn on the key i get power. So now looks like something to do with the blower motor ? that was the first thing i replaced. what do you think?
« Reply #32 on: December 03, 2013, 08:35:29 pm »
So what you are saying is with everything connected except for the blower motor you have B+ at the blower motor? Please clarify what's connected and what is not.
Offline darmentle
« Reply #33 on: December 03, 2013, 08:41:04 pm »
OK so everything is connected but the blower motor wire i turn the key on i have power at the blower motor wire the purple one. So then i go to re attach the purple wire to the blower motor with everything connected now i turn the key on and now i am losing power to blower motor wire.
« Reply #34 on: December 03, 2013, 08:43:56 pm »
OK and you have B+ at the orange wire still at the relay? After you confirm this you will need to run through a series of pinpoint tests.
Offline darmentle
« Reply #35 on: December 03, 2013, 08:45:39 pm »
10-4 i have power going to the big orange wire at the relay
« Reply #36 on: December 03, 2013, 08:55:11 pm »
After you've verified perform the following:
Reconnect all of the electrical connectors. Unplug the Blower Motor relay, connect your test light alligator clip to B+ and probe any ground to verify the light. Now take your probe and touch the terminal cavity for the relay #150 which is the black wire and ground for the relay. Your test light should light – Y or N?
Next with the key on engine off and the selector on heat and the fan switch in the high position, take your test light alligator clip to ground and touch B+ to verify the light. Now probe the smaller orange wire next to the black wire you just checked. It should illuminate – Y or N?
With your test light still connected to ground touch the big Orange wire at the relay connector and you should see your test light light up – Y or N?
Offline darmentle
« Reply #37 on: December 03, 2013, 09:00:16 pm »
Ok i will finish this tomorrow after work let you know thanks again
Offline darmentle
« Reply #38 on: December 04, 2013, 05:10:52 pm »
Ok start with the number 1
 1 Yes
 2 No  no power small Orange wire
 3 YES
« Reply #39 on: December 04, 2013, 05:45:50 pm »
OK so now go to your fuse panel under the dash and with the key on check the fuse for the heater by probing both sides with your test light connected to ground. I believe it's a 25 Amp fuse that's supposed to be in there. Report
Offline darmentle
« Reply #40 on: December 04, 2013, 05:54:15 pm »
The fuse is good have power going to both sides of it.
« Reply #41 on: December 04, 2013, 06:09:21 pm »
OK so next step to get to the switch in the dash
Offline darmentle
« Reply #42 on: December 04, 2013, 06:11:47 pm »
yeah i can pull that out check the connection. let you know make sure that the small orange wire is not cut
« Reply #43 on: December 04, 2013, 06:45:16 pm »
Hang on, I just looked at your picture and see a dk green wire cut and a dk green wire with double white stripe coming out of the relay harness correct? If so join those two wire together.
Offline darmentle
« Reply #44 on: December 04, 2013, 06:57:26 pm »
the one coming over by the relay is the one for the thermostaic switch i disconnected are you talking about the one next to the fire wall?
