Author Topic: Still no blower motor updated pics  (Read 46612 times)
Offline darmentle
« on: November 04, 2013, 08:18:52 am »
So its not working at all. So far i have done
-Replaced Relay
-Replaced and tested blower motor
-Checked Fuse
-Made Sure had power going into the HAC Control
I have power going into the relay but none coming out on the other side to that red wire that plugs into the blower. I am stumped. Maybe i got a faulty relay??
73 Chevy Factory Ac
Offline beastmode86
Re: Blower Motor Heater
« Reply #1 on: November 05, 2013, 01:27:19 pm »
 You can check your relay with a multimeter.
« Reply #2 on: November 05, 2013, 02:18:08 pm »
Do you measure power on the yellow wire at the blower resistor with the fan switch set to minimum?
Offline darmentle
« Reply #3 on: November 05, 2013, 04:14:49 pm »
No i havent measured anything with a multimeter yet i will try this week.
« Reply #4 on: November 05, 2013, 04:53:53 pm »
A test light will work just as well.
Offline darmentle
« Reply #5 on: December 01, 2013, 05:29:51 pm »
Still cant get the dang thing to work.
-Replaced blower relay
-Replaced blower
-Replaced blower resistor
-Cleaned wires and connections added a extra ground
-Getting 12 Volts to the resistor and 12 volts on both sides of the relay. just cant get power going to the red wire that goes to the blower motor.
Thoughts?
Worse case can i run the blower motor on a toggle switch ?
« Last Edit: December 02, 2013, 05:31:29 pm by darmentle »
Re: Still no blower motor
« Reply #6 on: December 01, 2013, 05:49:37 pm »
What are we working on here? Some details?
Offline darmentle
« Reply #7 on: December 01, 2013, 06:37:01 pm »
Sorry 73 chevy factory ac
« Reply #9 on: December 01, 2013, 07:20:50 pm »
Both orange wires with key on on high speed fan
Offline darmentle
« Reply #10 on: December 01, 2013, 09:28:36 pm »
yes i have B+
Offline darmentle
« Reply #11 on: December 02, 2013, 08:05:29 am »
So what i noticed is there is a fuse that is suppose to be inline coming off the junction block . I will  check on that later today.
Re: Still no blower motor updated pics
« Reply #12 on: December 02, 2013, 06:48:12 pm »
I was just going to ask where your 30AMP inline glass fuse is?
Offline darmentle
« Reply #13 on: December 02, 2013, 07:03:45 pm »
i don't see one the one wire coming off the junction box goes all the way to the battery. Also if i had that fusible link where does it plug into at? the blower relay ?
« Reply #14 on: December 02, 2013, 07:32:31 pm »
It's right above your thumb in the picture you posted
