After you've verified perform the following:Reconnect all of the electrical connectors. Unplug the Blower Motor relay, connect your test light alligator clip to B+ and probe any ground to verify the light. Now take your probe and touch the terminal cavity for the relay #150 which is the black wire and ground for the relay. Your test light should light – Y or N?Next with the key on engine off and the selector on heat and the fan switch in the high position, take your test light alligator clip to ground and touch B+ to verify the light. Now probe the smaller orange wire next to the black wire you just checked. It should illuminate – Y or N?With your test light still connected to ground touch the big Orange wire at the relay connector and you should see your test light light up – Y or N?
