Author Topic: 80 model k10 how to straighten steering wheel  (Read 9737 times)
Offline chevybones87
« on: November 13, 2015, 12:22:44 pm »
Hey guys I'm new to the club- Allen. From. Statesville NC...
 I've got my hands on a 80 model k10 its got some kind of aftermarket grant style steering wheel and its crooked as all get out.. How do I fix this its driving me crazy..thanks fellas
Re: 80 model k10 how to straighten steering wheel
« Reply #1 on: November 13, 2015, 12:23:42 pm »
Straighten ^^^^
Offline enaberif
« Reply #2 on: November 13, 2015, 12:28:20 pm »
It depends on where it isn't straight.
Usually it falls to the drag link. Look behind the driver tire and you'll see a sleeve connected by two joints. Adjust this sleeve to  move the steering wheel.
Little goes a long way.
« Reply #3 on: November 13, 2015, 12:31:45 pm »
Thanks ill definitely do that
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #4 on: November 13, 2015, 04:38:56 pm »
another option is to re-index the wheel on the shaft, normally just a nut and wheel puller needed-don't know about these trucks haven't pulled one apart before
 1986 Chevy K30(under repair)
Offline enaberif
« Reply #5 on: November 13, 2015, 05:45:38 pm »
No! Do not do this. Do it properly. By re-indexing the wheel anytime you do an alignment or front end work your wheel is going to be of again.
« Reply #6 on: November 13, 2015, 07:06:27 pm »
 Sorry, I should have been a little clearer, if alignment is correct and steering box centered, another option is to reindex the wheel. Being aftermarket it could be a spline or couple off
Offline Dr_Snooz
« Reply #7 on: November 13, 2015, 08:25:51 pm »
Presumably the wheel is not centered when the truck is driving straight down the road. In that case, simply re-positioning the steering wheel on the column spline-shaft would be the right way to do it. I have a Grant and with old sloppy steering, it's easy to get it off a few teeth when installing. My Grant sits crooked as well. No need for a wheel puller on mine. It just slips right off.
« Reply #8 on: November 13, 2015, 08:47:10 pm »
Don't over complicate things, you go all the way to the right and all the way to the left. The half way point is the middle. Do not remove and reposition it unless someone improperly installed the wheel. As said by enabarif you would adjust the drag link to center the steering wheel.
« Reply #9 on: November 14, 2015, 07:16:22 am »
I will check it all out today guys.. I would just jump straight to the drag link but, looking at all of the previous owners work there is really no telling if he installed it correctly or not. All of the horn stuff is in the glove box so I need to do that anyway...thanks again
Offline Dr_Snooz
« Reply #10 on: November 15, 2015, 08:37:57 pm »
LOL. My horn is compromised too.
