HYDRAULIC CLUTCH
Topic: HYDRAULIC CLUTCH (Read 10807 times)
CHUCK41
Newbi I want to say hello to everyone
HYDRAULIC CLUTCH
May 12, 2016, 09:52:29 pm »
I have a 1987 GMC V1500 350. 4speed Muncie SM465 transmission, it has a
11 inch hydraulic clutch, the flywheel, clutch disc, pressure plate, throw-out
bearing, were new in 2011 the truck did not move with it`s engine until last
Monday May 9th I put on a new clutch master cylinder, slave cylinder and line.
I have one inch of travel on the slave cylinder rod.is that enough ? is there more
then one slave cylinder for this truck? THANKS CHUCK41
don`t know why half my post got lost
Last Edit: May 13, 2016, 09:24:19 am by CHUCK41
CHUCK41
Re: NYDRAULIC CLUTCH
May 12, 2016, 10:21:20 pm »
what are you asking? or telling?
CHUCK41
May 12, 2016, 11:08:43 pm »
I`m telling you what I have and what has been done and what is happening, and I appreciate
any help . CHUCK41
CHUCK41
Blazin
Blazin new trails!
May 13, 2016, 05:03:00 am »
" I have a 1987 GMC V1500 350. 4speed Muncie SM465 transmission, it has a
bearing, were new in 2011 the truck did not move with it`s engine until last "
Okay?
This makes no sense as a question.
Is there a question hidden in here?
roundhouse
May 13, 2016, 08:38:31 am »
You Gotta finish the question
CHUCK41
May 13, 2016, 09:03:54 am »
:-[What could be wrong? could I have the wrong slave cylinder? is there more then one for this truck? is one inch of travel enough for the rod on the slave cylinder? THANKS CHUCK41
CHUCK41
zieg85
May 13, 2016, 09:08:36 am »
What is exactly the issue. Does the clutch not press in enough to dis-engage?
CHUCK41
Re: HYDRAULIC CLUTCH
May 13, 2016, 09:35:22 am »
Is one inch of travel on the slave cylinder rod enough to release the clutch? CHUCK41
Last Edit: May 13, 2016, 03:56:06 pm by CHUCK41
CHUCK41
roundhouse
May 14, 2016, 09:40:10 am »
Should be
Is it not releasing ?
These are very hard to bleed but if you're seeing one inch of movement that should work
CHUCK41
May 14, 2016, 07:45:57 pm »
ROUNDHOUSE THANK YOU
The clutch is not releasing, is there more then one slave cylinder for this truck? Last week I put
on a new clutch master cylinder, slave cylinder and line. The pressure plate, disc and throw-out
bearing were bought sometime between 2001 and 2011, when the engine was put back in the
truck. Last Monday was the first time it moved by it`s engine sjnce 2001. I don`t know if
any of the clutch parts are right. I`m thinking of pulling the engine and putting in a new clutch.
THANK KOU CHUCK41
CHUCK41
1967KaiserM715
1985 GMC K1500 w/ 6.5 TD
May 14, 2016, 10:25:57 pm »
Is the fork seated all the way, and did you make sure the throwout bearing was properly installed?
Current Vehicles:1985 GMC K10(Daily) 1991 GMC K2500(Daily) 1975 Beetle(not running) 1985 Mercedes 300D(not running) 1952 M35 1967 M715(not running)
1986 Chevy K30(under repair)
CHUCK41
May 15, 2016, 10:59:51 am »
1967KaiserM715 THANK YOU
It`s put together right but I don`t know if the clutch parts are right, and I don`t know if I
have the right clutch fork, ball stud or throw-out bearing. It`s been apart so long I`m not sure any of the parts are right. I think the only thing I can do now is pull it down and put in what I know are the new right parts.
THANK YOU CHUCK41
CHUCK41
1967KaiserM715
May 15, 2016, 12:40:14 pm »
I know when I threw my bellhousing on the fork felt weird (new fork and ball stud), turns out one of the spring clips that goes around the stud wasn't seated right, giving a lot of play in the fork, without putting pressure to the clutch
Sent from my LGL34C using Tapatalk
CHUCK41
May 15, 2016, 04:10:28 pm »
I`ll check that, it will be the next thing I do THANKS AGAIN CHUCK41
CHUCK41
May 15, 2016, 06:26:09 pm »
Sounds like you have air in the system.
HYDRAULIC CLUTCH
