Author Topic: 73-87chevytrucks.com - Jimmy Project  (Read 112378 times)
Offline okiesinmt
Re: 73-87chevytrucks.com - Jimmy Project
« Reply #30 on: December 18, 2007, 09:33:53 am »
Hey Chris
What are you using for engine management?
« Reply #31 on: December 18, 2007, 09:45:06 am »
127749 ecm (turbo app ECM)
Offline okiesinmt
« Reply #32 on: December 19, 2007, 04:08:21 pm »
I'm not familiar with the turbo appl.  What did it come off originally or is some burning a chip for the application?
« Reply #33 on: December 19, 2007, 04:47:29 pm »
The ECM was used on the Syclone/Typhoon/Turbo Sunbird.
« Reply #34 on: January 07, 2008, 05:09:01 pm »
Sunday January 6th, 2008: "rebuilt" a 1985 HEI unit from a Z28 so I can keep my current connections.  Now I just have to make an adapter to connect the 85 big cap HEI with the 87-95 HEI...
« Reply #35 on: January 07, 2008, 05:14:01 pm »
Isn't the distributor you put rebuilt a 4 wire ESC? Why not just use a newer distributor?
« Reply #36 on: January 07, 2008, 05:30:10 pm »
It is the computer off a 85 Z28 with Tuneport.  Its a 7 pin module not a 4 pin.  I didn't want to spring for an Accel or MSD yet until I get the turbo on it..
« Reply #37 on: January 07, 2008, 05:36:35 pm »
I meant it had the 4 wire pigtail that goes to the ESC module not the dist module. Sorry for the confusion.
« Reply #38 on: January 22, 2008, 11:09:18 am »
Saturday January 13th, 2008: Found out the Large cap HEI won't fit with the rear exit fuel lines.  Thought I had enough room but didn't...
Monday January 21st, 2008: picked up a 91 small cap distributor.
Offline JJSZABO
« Reply #39 on: January 22, 2008, 11:23:58 am »
Looking Good Chris ;)
Why turbos insted of supercharging?
Jeff
86 Chevy C-10
350, TH400
« Reply #40 on: January 22, 2008, 11:44:49 am »
1) My brother sells STS turbo kits via www.gracemotorsports.biz
2) They have unlimited operational range, and I can control it with just a wastegate.
3) Power potential is higher than a supercharger
4) I love the way they sound
This is my twin brothers 2000 RCSB with stock 5.3L and a STS remote turbo... (1/4mile was 12.28...@ 109.95mp)
http://www.gracemotorsports.biz/video/JCfreakvsSRT10Extd.mov
It now has a 6.0L in it and a bigger turbo housing...
Offline JJSZABO
« Reply #41 on: January 22, 2008, 01:37:15 pm »
Good points!!
I am partial to the mad max look - Big supercharger sticking out of the hood :D
I don't know much about turbos except they get their power from the exhaust.  Did you need larger injectors? How did you put it all together(design wise)?  Is your brother helping you?  I wouldn't know where to begin.
GREAT video - WOW!!  Thanks
« Last Edit: January 22, 2008, 01:45:16 pm by JJSZABO »
Jeff
86 Chevy C-10
350, TH400
« Reply #42 on: January 22, 2008, 03:42:22 pm »
I didn't build this motor with the intention of putting a turbo on it.  But I don't plan to put more than about 7lbs to it (maybe 10lbs once :D)
It does have low compression pistons which is required for any supercharging (turbo or blower) but I would feel better with forged pistons.
It does need larger injectors (It has 42lbs in it now)
He isn't helping me on this one, his company is basically a partnership between us.  He does the ECM tuning for the 99-up trucks, and I will be using it when I twin turbo my 73-87chevytrucks pickup as it has a 6.0L/4L80E out of a 2000 pickup...
You can put a turbo on just about anything if you don't plan to go overboard.  They should be able to take about 5lbs in a driver...  I wouldn't attempt a carb'd turbo app though.  Mainly because I don't like carbs.
Offline 82chevy
« Reply #43 on: January 22, 2008, 05:28:50 pm »
thats awsome that ur going to be running a turbo. ive been looking into it recently and thinking about getting a small turbo and fab up all the pipes for it myself or if i can, ill buy some turbo headers instead of building them. are you going to be running it under the truck like the sts kits or under then hood? before i attempt this i need to get my new engine first lol. i definitely want more info on this project haha
« Reply #44 on: January 22, 2008, 05:33:39 pm »
Can you post some pix of your Jimmy? (the truck) lol
