Author Topic: 79 C-10 5.3/4L60E--MOVING ON TO BODY WORK  (Read 92072 times)
Offline bowtieguy
  • Country as a Cow Pie
« on: December 12, 2007, 09:28:19 am »
Its probably been 2 years since I have been on this site.
Wanted to show you all my project I have been working on since last summer.
I found a 5.3/4L60E combo at the local salvage yard with 93K miles on both.
The swap is coming to an end.  I am keeping it stock for now to get a base line of what I have for now.  It is going to have a Custom EFI live tune, as well as home made cold air intake, with dual exhaust.
Any ways, here are some pics of my progress.
« Last Edit: March 03, 2008, 09:20:03 pm by bowtieguy »
Toys:
89 Black Lesabre T 62k miles
03 Lesabre Celebration Edition
08 NNBS CC Z71 LTZ
79 Flat BlackChevy C-10  5.3/4L60E
Re: 79 C-10 5.3/4L60E
« Reply #1 on: December 12, 2007, 10:55:59 am »
Nice setup Bowtie.  Are those your fuel lines wrapping around the back from the front?
Offline bowtieguy
« Reply #2 on: December 12, 2007, 12:03:36 pm »
yes they are, in the pictures they are laying loose.  I used some P clips to hold them to the intake, and got a set of these:  http://store.summitracing.com/partdetail.asp?autofilter=1&part=MFY%2D2052211&N=700+0&autoview=sku
Not sure if it was a wise idea or not, but I used tube adaptors to -6 fittings on the factory fuel lines.  I had to use the vent tube ( being 5/16's ) since the factory return line is only 1/4".  I also used a sending unit from an 87, I did the same on the sending unit, used the tube to -6 fittings.  ( 87 return line was already 5/16's ).  So the tank is -6 stainless steel braided hose to the factory fuel line, running up to where the fuel pump would mount.  Once again used the tube to -6 and ran the lines you can see in the picture.  Keeps that factory feel to what we are used to on the 73-86 trucks.
I did run the pump and had no leaks, so "should" be ok.
Toys:
08 NNBS CC Z71 LTZ
Offline Fordeatinz71
  • 78k miles and counting
« Reply #3 on: December 12, 2007, 05:58:28 pm »
awesome setup!  nice looking truck and install...
Offline bowtieguy
« Reply #4 on: December 13, 2007, 12:41:02 pm »
Thanks man
Toys:
08 NNBS CC Z71 LTZ
Offline bowtieguy
« Reply #5 on: December 13, 2007, 08:29:16 pm »
Got some more pics taken off the camera, some from this evening.  What do you think of my Fuse block.  Found that at the junk yard in a 94 Bonniville SSE.
Toys:
08 NNBS CC Z71 LTZ
Offline JJSZABO
« Reply #6 on: December 14, 2007, 08:18:09 am »
Looking good ;)
Jeff
86 Chevy C-10
350, TH400
« Reply #7 on: December 14, 2007, 05:52:06 pm »
Where'd your heater box go?
Offline bowtieguy
« Reply #8 on: December 15, 2007, 05:50:08 pm »
Removed it to keep from breaking it when I dropped the engine in.  I put the engine tranny in alone, and it was really really close when my dad helped me mock it up.  It laying in the bed.  Going back on when I take the front clip off for paint.
Toys:
08 NNBS CC Z71 LTZ
Offline 123 pugsy
« Reply #9 on: December 16, 2007, 05:51:07 pm »
Nice truck. ;D Looking good. What kind of power does a 5.3 have?
Pugsy
76 C10 LWB
TPI 350
Offline team39763
« Reply #10 on: December 16, 2007, 07:31:59 pm »
That's comin along real good.
Offline bowtieguy
« Reply #11 on: December 16, 2007, 09:02:33 pm »
mine is a 2000 Silverado engine.  Rated at 285hp 325tq.  That is stock with all the smog goodies.  Uncorked should be pushing 310HP 345TQ with a good healthy tune in it.  Or more...
Toys:
08 NNBS CC Z71 LTZ
Offline 123 pugsy
« Reply #12 on: December 17, 2007, 04:54:03 am »
[/quote]
Nice.  8)
Pugsy
76 C10 LWB
TPI 350
Offline bowtieguy
« Reply #13 on: December 17, 2007, 08:54:48 pm »
I just got inside from working on the truck.  The shifting linkage from the TH350 not only fit to the 4L60E but needed no adjustment, goes from P all the way to 1!!!!!  Can't beat it!  First the drive shaft fit and now this!  Something has got to go wrong sooner or later.... hope I didn't jinks my self.
Toys:
08 NNBS CC Z71 LTZ
Offline JJSZABO
« Reply #14 on: December 18, 2007, 07:43:20 am »
Hurry, throw some salt over your shoulder or something before you ruin your good luck streak :o
Good job!!  It's nice when things go good without anticipating it.
Jeff
86 Chevy C-10
350, TH400
