Author Topic: 83 c10 re-innovated Pro Touring  (Read 516918 times)
Offline eventhorizon66
Re: 83 c10 re-innovated, air ride
« Reply #135 on: August 12, 2009, 04:20:04 pm »
Oh, I was thinking in terms of simply reproducing a factory a-arm in tubular steel.  My brain fart, I guess.  My way wouldn't make much sense if you intend to change the mounting angle of the ball joint.
« Last Edit: August 12, 2009, 10:09:35 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline the dan
« Reply #136 on: August 12, 2009, 10:02:45 pm »
haha yes sadly the ball joints max out when i hit the air ride
Offline the dan
« Reply #137 on: August 16, 2009, 03:37:57 am »
so i have ballin rear brakes:
finally got some rotors and the calipers are wrong, they gave me ones for 1 inch front rotors on a chevy instead of the 1 1/4 i have, so napas in action tomorrow, then started working on all the other jigs till i ran out of bolts and nuts, night time work is so much better in ct, its 68 degrees out, tomorrows going to be 92, so boats not trucks lol
« Last Edit: August 17, 2009, 08:01:07 pm by Captkaos »
Offline LUV2XCLR8
    • TNCTC.com
« Reply #138 on: August 16, 2009, 07:21:48 am »
WoW, just read it all from start to finish, impressive to say the very least.
Question, when it was 5/5 drop (Before you went air) was it sitting level?
72 PROJECT: "YFTSB"
81 DRIVER: "GLACIER"
Offline the dan
« Reply #139 on: August 16, 2009, 09:43:18 am »
the rear was maybe an inch higher then the front
Offline LUV2XCLR8
    • TNCTC.com
« Reply #140 on: August 16, 2009, 09:57:03 am »
TY, I just bought a 81 Blazer and want the front back to springs
(It's bagged up front) & the rear is a 5" flip kit + it's c-notched.
72 PROJECT: "YFTSB"
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #141 on: August 18, 2009, 09:19:08 am »
What type of kit did you use for the rear bakes?  Thanks
Don't wear a tux without the BOWTIE!!!
Offline the dan
« Reply #142 on: August 19, 2009, 12:04:27 pm »
a build your own kit.. haha, ford 9" is much different than a GM axle but those are front rotors off a 98 dodge ram, and C10 front brakes for the 1-1/4 front rotors, im building my own caliper brackets
Offline the dan
« Reply #143 on: August 19, 2009, 11:51:20 pm »
so today i came up with an awesome idea.
What the heck am i going to use my other 4-link for? im going to make my A-arms out of it :) atleast my tops
so i turned down the shafts tonight to fit 9/16
Poly mount + DOM
have to turn down both sides, and even bring the shaft longer to accept the width of the 2.5 inch poly mount.. i will thread the ends when im done with it all
i guess i didnt hit the resize button, sorry ill make them small next time
Offline the dan
« Reply #144 on: August 28, 2009, 08:07:05 pm »
So im ditching the muncie, i got a new idea
t56, 6 speed, $150
blown but im going to rebuild it
« Reply #145 on: August 29, 2009, 08:46:16 am »
Awesome! I gotta check this thing out in real life soon.
Offline treepete
« Reply #146 on: August 29, 2009, 04:16:15 pm »
I stalk this thread and never post much. jut wanted to say its coming along nicely. the best thread for me to read.
thanks.
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
Offline the dan
« Reply #147 on: August 29, 2009, 06:58:36 pm »
haha thanks, ran into a wall today, i need a 1-1/4 die for my tubing bender, that sets a-arm work back a week, and i cant build my rear any more because now i need different gear ratios
Offline the dan
« Reply #148 on: September 22, 2009, 12:12:25 am »
Got some stuff, sent some stuff back.. you know how it works
Motive gears 4:11's for the rear, purchased a mag base some indicators, and tooling for the lathe/bridgeport
got my tubing die, as you can see started playing with the a-arms
Also started tearing into the t56. Not a fun transmission to work on let me tell you..
And as always school is killing my truck work time, tonight was the first night i got work done in 3 weeks
Offline truckjunky
« Reply #149 on: September 22, 2009, 04:03:39 pm »
Dude. You have a sick truck. 8) Your doing an awsome job keep up the good work. ;D Bummer about school taking up your time on the truck,but it will be worth it in the end. ??? ;)
Life to short to drive anything else!:chevy:
