Author Topic: 83 c10 re-innovated Pro Touring  (Read 497068 times)
Offline the dan
Re: 83 c10 re-innovated, air ride
« Reply #375 on: July 24, 2013, 11:31:08 pm »
the stock c5 corvette ones are out back
Offline the dan
« Reply #376 on: November 26, 2013, 01:15:15 am »
bed finally got back to the shop
then put onto the truck after extensive cutting and bracing
cut the bed to clearance for the roll cage
So i had to cut an access hole in the bed floor for my air ride distribution box. God forbid i blow a compressor line i would never be able to get the truck back into the air or even get a jack under it
Matt Van Overloop from DFT plasma (http://www.pro-touring.com/threads/89377-53-Plymouth-Belvedere-Build) found me some Hartwell latches that i am going to use
« Reply #377 on: November 27, 2013, 09:08:27 pm »
You should build in an integrated air/hydraulic jack ;) Great progress!
« Reply #378 on: December 05, 2013, 07:28:46 am »
Dan,
I put you in for the March section.  http://forum.73-87chevytrucks.com/smforum/index.php?topic=27000.msg224793#msg224793
If you can send me more pics please do!
Offline the dan
« Reply #379 on: December 05, 2013, 09:30:29 am »
hey capt, ill try and get some professional shots for you!
« Reply #380 on: December 05, 2013, 02:29:33 pm »
Awesome.
captkaoscustoms.com
squarebody.biz
Offline the dan
« Reply #381 on: January 19, 2014, 10:41:40 pm »
The fender replacement pieces they sold me were no where near close so I rolled and cut and file fit my own
Got my mastercraft seats in
oh i bought a new toy and made a stand for it too... should be able to make some cool stuff with it
Offline the dan
« Reply #382 on: February 20, 2014, 04:19:07 pm »
driverside inner fenders are almost done
« Reply #383 on: February 20, 2014, 10:26:37 pm »
     That is some impressive work you have done, are you still going to want to drive it when you are done.
Offline dvdswan
« Reply #384 on: February 21, 2014, 11:35:14 am »
one simply amazing build you have here.
« Reply #385 on: February 22, 2014, 09:17:14 am »
Awesome!
Offline the dan
« Reply #386 on: February 27, 2014, 01:01:00 am »
more than ever!
finished the inner fenders, just one more spot to do
« Reply #387 on: February 27, 2014, 06:38:45 pm »
That looks awesome!
Offline 87V20Kansan
« Reply #388 on: February 27, 2014, 08:04:52 pm »
This truck is so cool.
Cecil: 1987 V20, TBI 350, TH400, 4:10's, 7" lift, 37" H1 beadlocked runflats. Cummins swap someday.
Offline tex62
  • Lurker
« Reply #389 on: April 12, 2014, 06:59:41 am »
So I noticed you welded in the cross member over the motor. So what happens if the motor goes and you need to pull it? Guess it isn't a big deal to cut and weld it back in place though when the time comes.
87 chevy suburban. 350 tbi w/ 700r4. 2wd sluggish tank sporting plastidip paint.
