General Discussion
gauges....Again...
4
Topic: gauges....Again... (Read 38004 times)
Redneckchevy
Re: gauges....Again...
Reply #30 on:
March 20, 2008, 01:56:22 pm »
Well im still lost about them wires....Cant get the fuel gauge to work right...
it looks like i should just have 2 grounds and then a Tan and white...But it moves it past fool..Then if i use a Dark brown wire..That acts like a ground it goes way past empty....Then if i touch the other Dark brown wire against 1 or 2 of the pink wires with black stripes it does the seat belt buzz but dont go off....So thats it...All i need help with is the seat belt and the fuel gauge....And also if i put a black ground wire into the Fuel slot it lights up both my turn singels and My chilton book is crap
Reply #31 on:
March 20, 2008, 06:16:57 pm »
can you se the pinouts? if not click on the links
here's what you had
here's what you are putting in.
All you have to do is match up the connector in the picture to be like in the second picture and then you should just plug it in... Take a look at them and compare with what you've got.
http://i6.photobucket.com/albums/y228/Sabaka454/withgaugesnotach.jpg
Redneckchevy
Reply #32 on:
March 20, 2008, 07:23:52 pm »
hmmm cant get the link to work
Redneckchevy
Reply #33 on:
March 20, 2008, 11:10:37 pm »
Ware do i find the colors at on the diagram?
Redneckchevy
Reply #34 on:
March 21, 2008, 07:25:58 pm »
vile....i hate to ask u for the color code again...but ur the only one that will put up with my 1000 quastions about the same thing lol
KoolerSL2
Chevy / Ford: A house Divided
Reply #35 on:
March 22, 2008, 12:29:15 pm »
hey red was your truck a custom deluxe?
also was it a light truck?
if so i can get you the pinout off my cluster with the colors to help ya out.
1985 C10 LWB: gone but never forgotten
1987 R10 LWB: 107k mile near original survivor
2020 Mustang GT: 6sec 1/8mi driver
https://m.facebook.com/pages/category/Automotive-Customization-Shop/HPR-105373468425153/
Redneckchevy
Reply #36 on:
March 22, 2008, 02:33:29 pm »
yea man 1986 Customdeluxe swb k10
Reply #37 on:
March 22, 2008, 02:36:33 pm »
Didn't i post that in your other thread already? That schematic I just posted isn't showing you colors just circuit numbers and pinout locations.
Redneckchevy
Reply #38 on:
March 22, 2008, 04:04:47 pm »
no i looked at that...My truck has diffrent color wires then that....That and im getting mad at it...So old the ends are snapping off the wires....I dont have the time or money to get a new wire harness and another set of gauges...i already spent 400$ on this junk cause it keeps breaking
KoolerSL2
Reply #39 on:
March 22, 2008, 11:09:47 pm »
well when i wake up ill get ym harness and take a pic of wires and such and let ya know what mine were.
Reply #40 on:
March 23, 2008, 07:33:48 am »
redneck do you have a meter? I think you need to just do a few continuity test.
For example, take the coolant sender wire and hook it to one end of your meter, then take the other probe and touch each wire until you find the one that has continuity. Then just put it in the proper pin location in the connector.
Redneckchevy
Reply #41 on:
March 23, 2008, 09:17:09 am »
That would help kooler....And vile would i be looking for ohms or just volts?
Reply #42 on:
March 23, 2008, 09:40:40 am »
Ohms Ω. Or continuity test if your meter has the function. Most decent ones do and will beep if you short the leads which makes it easier to test. It may have a diode symbol which looks like an arrow with a line. When shorted it should read zero.
Redneckchevy
Reply #43 on:
March 23, 2008, 02:12:00 pm »
yea i got a good one ill try that..
Redneckchevy
Reply #44 on:
March 26, 2008, 07:46:43 pm »
Well...I got it....And the oil leak.....Leak was from the oil pressure line...And I ran a new wire from gas tank...
4
General Discussion
gauges....Again...
