Author Topic: hood rust  (Read 61780 times)
Offline hotrod24
Re: new fender
« Reply #30 on: March 28, 2008, 02:29:10 pm »
see in the top pic you can see where the other fender was the blue on the radiator support it should come over a little more all of the 73-80 are the same so i dont know what it could be
1978 pontiac grand prix...
Offline Bitzer!
  • Smiles per gallon
Re: new fender
« Reply #31 on: March 28, 2008, 02:35:30 pm »
have you left ALL the bolts slightly loose and then line it up and then tighten? Its amazing how much 1/4" can give you 3/4" else where   ;)
1979 GMC CrewCab  C20 1t
Re: new fender
« Reply #32 on: March 28, 2008, 09:02:58 pm »
Hotrod, where isn't it lining up? The 73-80's were a lot more tough with the body lines. Loosen up the inner fender too or take it right out when you're trying to line up the fender.
Re: new fender
« Reply #33 on: March 28, 2008, 10:26:32 pm »
Don't be surprised if you have to break out a porta power to get stuff to line up correct. Or just brute force, & ignorance!! ;D
 Just remember middle school, fulcrums etc.
Offline hotrod24
Re: new fender
« Reply #34 on: March 28, 2008, 10:32:21 pm »
its not close enough to the radiator support the top of it anyway
« Last Edit: March 28, 2008, 10:56:09 pm by hotrod24 »
Offline Dragon
Re: new fender
« Reply #35 on: March 29, 2008, 12:44:39 am »
Looks like you don't have it properly seated on the Radiator Support.. Try loosing or unbolting the front of the fender, then pick it up and shove it over to fully seat it on the support, then retighten or reinstall the bolts...
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Re: new fender
« Reply #36 on: March 29, 2008, 09:31:04 am »
I have had to actually encourage the inside of the fender ( second pic. ) with a rubber mallet in the past to get it to tighten up to the support.
Offline hotrod24
Re: new fender
« Reply #37 on: March 29, 2008, 11:39:41 am »
it is supposed to be like the third pic right if any of you have any pics of this area it would really help
Re: new fender
« Reply #38 on: March 29, 2008, 12:01:54 pm »
Actually the left, & right hood lines should be what determin how far in the fender is. Not going to do a whole lot of good if you force it to fit like the third pic, & then when you shut the hood it comes down on top of the fender. In theory it should be close or the same as the third pic. But if the hood fits I would leave it alone. the gap between the fender, & hood shouldn't be much bigger than 1/8".
Offline hotrod24
Re: new fender
« Reply #39 on: March 29, 2008, 12:19:02 pm »
well i think this is as far as it will go could the radiator Support be out of line this truck was rebuilt so it could have been in the wrong hands
« Last Edit: March 29, 2008, 12:55:20 pm by hotrod24 »
Re: new fender
« Reply #40 on: March 29, 2008, 01:08:43 pm »
Looks like it. Does the hood lines match? If the hood line gets bigger at the front on one side and smaller at the front on the other side the support needs to be moved over. That will still not make the fender get closer to the support though. Like I said a few posts back. I have actually taken a rubber mallet and massaged the inside of the fender to get the gap to close up.
Offline hotrod24
Re: new fender
« Reply #41 on: March 29, 2008, 01:24:49 pm »
so the hood and the radiator Support is my problem not the fender but if i took a rubber mallet or something could i get the fender closer
« Last Edit: March 29, 2008, 01:37:17 pm by hotrod24 »
Re: new fender
« Reply #42 on: March 29, 2008, 02:00:20 pm »
I have no idea what the problem is, as I am not there. You need to access the situation and make a determination using my and others input. several posts now and I still don't know if your hood lines are right or wrong?? I don't know how else to explain it to you except if the hood lines up good why are we even concerned about how close the top lip of the fender is to the core support?
 I was just stating that in the past when I have had issues with the fenders being to far away from one another, hence making the hood gaps to wide. I have used one for lack of other words, bash the inside of the fender in along the mount area to the core support to get the two of them closer together. Please don't use anything on anything until you know if the hood lines up or not.
Offline hotrod24
Re: new fender
« Reply #43 on: March 29, 2008, 02:15:22 pm »
sorry about that, the hood is not right the hood does not even latch right boy it did you did not have to it push down to shut it
« Last Edit: March 29, 2008, 02:24:18 pm by hotrod24 »
Re: new fender
« Reply #44 on: March 29, 2008, 02:22:23 pm »
Did it latch before you took the old fender off? Is it the latch? How are the body lines off? Which way?
