Author Topic: hood rust  (Read 61755 times)
Re: new fender
« Reply #75 on: April 15, 2008, 07:08:56 am »
No idea, never had that happen.
Offline JJSZABO
Re: new fender
« Reply #76 on: April 15, 2008, 08:56:25 am »
Post pics so we can see.
Jeff
86 Chevy C-10
350, TH400
Offline hotrod24
Re: new fender
« Reply #77 on: April 15, 2008, 12:19:19 pm »
here thay are if you need anymore pics just let me know
1978 pontiac grand prix...
Re: new fender
« Reply #78 on: April 15, 2008, 02:19:11 pm »
I have no idea what we are actually looking at other than a bezel.  What is behind the bolt holes?
Offline Toolmaster
Re: new fender
« Reply #79 on: April 15, 2008, 02:37:17 pm »
Try taking the screws out, Then start each one before tightening the others. Slowly turn each one a few turns till they all pull up. You may be able to adjust the bezel around a bit as you go.
Most of the time with sheet metal and trim type thing its better to get all the bolts/screw's started before tightening single bolts down.
Offline Swims350
    • Cars and trucks
Re: new fender
« Reply #80 on: April 15, 2008, 05:26:51 pm »
agreed, if nothing else remove it and make sure all clips are there or holes aint stripped or oversized. I've used whatever I could fit in the screw hole to move clips around and line em up, or put in new ones.
www.cardomain.com/id/benwa454
Re: new fender
« Reply #81 on: April 15, 2008, 06:16:54 pm »
Line the clips up with a piece of masking tape if they are moving and line them up one at a time. Is the bezel not sitting correctly?
Offline hotrod24
Re: new fender
« Reply #82 on: April 15, 2008, 07:10:06 pm »
i pushed the clips over and put it back on but that did not do anything
Re: new fender
« Reply #83 on: April 16, 2008, 03:01:37 am »
If the clips are moving around take them off and pinch them with some pliers, then reinstall them. They should fit pretty tight. Then use a strait pick to line them up with the holes, through the head light door / bezel.
Offline hotrod24
Re: new fender
« Reply #84 on: April 16, 2008, 04:26:49 pm »
ok thanks
« Last Edit: May 17, 2008, 02:44:27 pm by hotrod24 »
Offline hotrod24
Re: new fender
« Reply #85 on: May 17, 2008, 02:45:34 pm »
hey is there a way to take the inner fender out without taking the fender off
Offline HAULIN IT
Re: new fender
« Reply #86 on: May 17, 2008, 02:54:45 pm »
Yes, If you take all of the bolts out, it will practically fall down & hit you on the head while removing the last bolt. I always install the inners after the fenders are installed. It makes lining up the fender easier I feel. Lorne
Offline hotrod24
Re: new fender
« Reply #87 on: May 17, 2008, 03:04:02 pm »
thanks Lorne
Offline hotrod24
Re: hood rust
« Reply #88 on: June 04, 2008, 07:25:00 pm »
ok my hood is in good shape but there is some rust holes in the inside all i can think to do is take some sheet metal and weld it in place i thought about just getting a new hood but i dont know if i can fix this one or not
Re: hood rust
« Reply #89 on: June 04, 2008, 08:11:24 pm »
I would just get a new hood.... if the truck is going to be worth it just wait and get a nice steel cowl hood.
