Body, Glass & Paint
hood rust
4
5
6
Topic: hood rust (Read 61771 times)
hotrod24
Re: new fender
Reply #45 on:
March 29, 2008, 02:37:37 pm »
yea it latched good before i took the fender off i would say to the left thay are off what is that best way to fix it
Last Edit: March 29, 2008, 03:09:37 pm by hotrod24
1978 pontiac grand prix...
hotrod24
Re: new fender
Reply #46 on:
March 29, 2008, 03:28:06 pm »
blazin you just tell me what to do and i will do it but to save you time i still have to get a passenger fender so it would be best to get it first and then fix the hood
red4wd
Re: new fender
Reply #47 on:
March 29, 2008, 03:35:41 pm »
It appears that the hood was bolted back on wrong...did you get the bolts back in the same position where they came out? I would start by loosening the all of the hood bolts and move the right side forward and the left side back. That should get you close.
hotrod24
Re: new fender
Reply #48 on:
March 29, 2008, 03:40:58 pm »
yea i looked at the fender that i took off and put it in the same place but that did not help
red4wd
Re: new fender
Reply #49 on:
March 29, 2008, 03:52:03 pm »
Take some close up pics of the hood hinges where they are bolted to the hood.
Bitzer!
Smiles per gallon
Re: new fender
Reply #50 on:
March 29, 2008, 03:58:15 pm »
If you took all the fixings out and pushed the fender up does it line up? if it does the re-drill the holes and bolt up
1979 GMC CrewCab C20 1t
hotrod24
Re: new fender
Reply #51 on:
March 29, 2008, 04:09:35 pm »
hotrod24
Re: new fender
Reply #52 on:
March 29, 2008, 04:11:50 pm »
if you need more pics let me know
Blazin
Blazin new trails!
Re: new fender
Reply #53 on:
March 29, 2008, 04:18:41 pm »
I would try to slide the right side forward, & the left side back if it will go anymore.
Looks like your left hood hinge needs to drop down on the fender too.
Last Edit: March 29, 2008, 04:21:50 pm by Blazin
red4wd
Re: new fender
Reply #54 on:
March 29, 2008, 04:19:30 pm »
loosen the bolts on the passenger side and slide the hood forward and see what that does for you.
hotrod24
Re: new fender
Reply #55 on:
March 29, 2008, 04:21:35 pm »
ok thank you
hotrod24
Re: new fender
Reply #56 on:
March 30, 2008, 12:55:30 pm »
was there any differences on the 73-80 fenders on the inside i know what i have read and yall have told me but i looked at my old fender and my new one and thay are different at the top i think this is the problem
Last Edit: March 30, 2008, 02:02:41 pm by hotrod24
hotrod24
Re: new fender
Reply #57 on:
March 31, 2008, 01:59:29 pm »
is this a problem or am i just being paranoid because the fender fits its just got that gap where the hood closes
Re: new fender
Reply #58 on:
March 31, 2008, 02:37:40 pm »
I can't really tell from the pics, but it appears you need to shift the core support over if the gaps at the back are ok and the fronts are off...
hotrod24
Re: new fender
Reply #59 on:
March 31, 2008, 02:48:38 pm »
its fine on the back but the front that is as close as it will go to the radiator support
Last Edit: March 31, 2008, 02:53:17 pm by hotrod24
4
5
6
Body, Glass & Paint
hood rust
