Author Topic: Pipe plugs..where to buy.  (Read 12471 times)
Offline overthepond
« on: April 11, 2008, 04:56:13 am »
Hello,
Can anyone advise me on where i could get a pipe plug to fill the sender hole in a Edelbrock performer intake.(nearest to thermostat housing).
I was gonna fit a switch to control the fans i'll be fitting but cant find a suitable piece to fit.
Any help is greatly appreciated.. ???
Dave.
Dave
Offline Prong
Re: Pipe plugs..where to buy.
« Reply #1 on: April 11, 2008, 05:04:33 am »
I'd try a hardware store, or perhaps a plumbing supply shop if that fails.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline overthepond
« Reply #2 on: April 11, 2008, 05:10:37 am »
Thanks,
My bro in law is a plumber and i had a look in his supplys the other day but nothing came close,found a multi set of plugs on that auction site but not sure if it contains the one plug i need.
Trial and error i suppose.. ;D
Dave
« Reply #3 on: April 11, 2008, 06:20:35 am »
Can you even get fittings with NPT over there?
Offline overthepond
« Reply #4 on: April 11, 2008, 06:31:54 am »
Not sure Blazin,i have a nut/bolt supplier locally who i usually use for stuff i cant get elsewhere,if i had the correct measurements he could probably fix me up...
Dave
Offline frogman68
« Reply #5 on: April 11, 2008, 06:37:44 am »
Heres a thought could it be that silly metric system again??
Its Sae or Pipe , tube threads and you are looking at metric fittings . Got a pic ?
Offline overthepond
« Reply #6 on: April 11, 2008, 06:55:02 am »
Here ya go,sorry for the quality pic im using the stoneage camera.. ;D
Dave
« Reply #7 on: April 11, 2008, 10:41:37 am »
An autoparts store should have one. Be careful when installing one too, they are usually tapered and will crack the manifold if you overtighten it.
Offline overthepond
« Reply #8 on: April 11, 2008, 11:31:11 am »
Maybe in your town but not here,i asked at a local major motor shop recently for a timing gun and they asked what it was and what it does..lol
Dave
« Reply #9 on: April 11, 2008, 12:57:18 pm »
well if it's a 1/2" pipe plug you could take the one out of the rear end lol
Offline eventhorizon66
« Reply #10 on: April 11, 2008, 01:15:22 pm »
Yes its 1/2" NPT (same size as the plug in the cylinder head) and the smaller ones are 3/8" NPT.  Use a brass allen head plug, it will seal better and the plug will strip out before the manifold does.  I tried using a set of galvanized steel plugs from AutoZone all over my engine.  Every single one of them leaked no matter how tight (yes I used a thread sealer).  Replaced them all with brass, no problems now.  Also the sealer I used was teflon grease from ARP.
« Last Edit: April 11, 2008, 02:00:34 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline overthepond
« Reply #11 on: April 11, 2008, 01:20:05 pm »
Thats great,thanks for all the help guys..... ;D
Dave
Offline Stewart G Griffin
« Reply #12 on: April 11, 2008, 02:28:15 pm »
You could try these two sources:
http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&Ntt=pipe+plug&x=0&y=0&N=700+115&searchinresults=false
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&langId=-1&N=0&Ntt=pipe+plug&Ntk=all&Nty=1&D=pipe+plug&Ntx=mode%2Bmatchallany&Dx=mode%2Bmatchallany&searchTerm=pipe+plug
i've always been curious as to parts availability/accessability  for an American-made vehicle in other lands---such as England.  i suppose with worldwide couriers such as UPS, DHL etc. it's not a problem anymore?  i'm almost positive the above two companies ship to England as well as worldwide.
Even though i can virtually get any part i need from auto parts stores and/or the dealer, i, for the most part, end up getting them from the above two stores---and have them mailed to me;  So, i suppose, in the  end, it does not matter where you live.
Offline overthepond
« Reply #13 on: April 11, 2008, 03:02:34 pm »
Thanks for the links,
I think it'll cost a bomb with summit as they require a $23 handling fee on top of the final price if i remember correctly.
I plan on shopping locally tomorrow so i'll be back with my findings asap.. ;)
Its real easy getting parts over here,but nothing i buy comes from the rip off merchants over here that call themselves dealers.
All parts come from ****AUTO and that auction site with a 4-5 day delivery time and half the cost. ;D
« Last Edit: April 11, 2008, 03:10:39 pm by overthepond »
Dave
Offline blast
    • JamRoom
« Reply #14 on: April 11, 2008, 03:18:55 pm »
Most hardware stores carry pipe plugs, but I don't know how many will carry the brass plugs.
