Author Topic: spark plugs too HOT  (Read 5064 times)
Offline black82
spark plugs too HOT
« on: September 10, 2008, 04:32:50 pm »
i have a 454 in my truck and according to the ground strap the autolite 24 plug is too hot does anyone have any recommendations of what ones to use
Re: spark plugs too HOT
« Reply #1 on: September 10, 2008, 05:19:16 pm »
According to the ground strap?  ???
What year is your engine?
Offline black82
« Reply #2 on: September 10, 2008, 06:01:55 pm »
The ground strap indicates the heat range of the spark plug    idk what year the block is
Offline DnStClr
« Reply #3 on: September 13, 2008, 12:21:06 am »
Ground strap info- I never knew this before. Thanks black82.
http://www.carcraft.com/howto/116_0703_spark_plug_guide/ignition_timing.html
Ground Strap differences
« Last Edit: September 13, 2008, 12:41:08 am by DnStClr »
Don
87 Chevy Silverado
« Reply #4 on: September 13, 2008, 12:04:45 pm »
So you are saying you're reading your plugs and the ground electrode appears to discolored making you think the plug is too hot. What is your ignition timing? If you want to run Autolites use plug #145
Offline black82
« Reply #5 on: September 14, 2008, 11:58:49 am »
http://www.angelfire.com/fl4/pontiacdude428/Readplugs.html
this write up is what i was going off of to say they were to hot... my timing is at 38 the motor is prob  10:5 to 1
