Performance
spark plugs too HOT
Topic: spark plugs too HOT (Read 5061 times)
black82
spark plugs too HOT
September 10, 2008, 04:32:50 pm »
i have a 454 in my truck and according to the ground strap the autolite 24 plug is too hot does anyone have any recommendations of what ones to use
Re: spark plugs too HOT
September 10, 2008, 05:19:16 pm »
According to the ground strap?
What year is your engine?
⌠ŻŻŻŻŻ' [☼===☼]
black82
September 10, 2008, 06:01:55 pm »
The ground strap indicates the heat range of the spark plug idk what year the block is
DnStClr
September 13, 2008, 12:21:06 am »
Ground strap info- I never knew this before. Thanks black82.
http://www.carcraft.com/howto/116_0703_spark_plug_guide/ignition_timing.html
Ground Strap differences
Last Edit: September 13, 2008, 12:41:08 am by DnStClr
Don
87 Chevy Silverado
September 13, 2008, 12:04:45 pm »
Quote from: black82 on September 10, 2008, 06:01:55 pm
So you are saying you're reading your plugs and the ground electrode appears to discolored making you think the plug is too hot. What is your ignition timing? If you want to run Autolites use plug #145
⌠ŻŻŻŻŻ' [☼===☼]
black82
September 14, 2008, 11:58:49 am »
http://www.angelfire.com/fl4/pontiacdude428/Readplugs.html
this write up is what i was going off of to say they were to hot... my timing is at 38 the motor is prob 10:5 to 1
Performance
spark plugs too HOT
