Author Topic: Will a '82 tailgate fit a '76 truck???  (Read 17612 times)
Offline txtj79
  • 1980 Chevy C-10 SWB
« on: October 07, 2008, 08:59:32 pm »
I have a 76 C-10 and I need a tailgate.  Found one on craigslist for an 82.  Will it fit?  Is the latch system and mounting the same?
Thanks,
T.J.
Re: Will a '82 tailgate fit a '76 truck???
« Reply #1 on: October 07, 2008, 09:13:48 pm »
the latch is slightly different I believe.
Offline ccz145a
« Reply #2 on: October 07, 2008, 10:56:01 pm »
trunions are different, too. good news is the right ones will bolt on. pretty sure the latch will work, but you need to bolt on '82 drop bars.
« Reply #3 on: October 07, 2008, 10:56:38 pm »
The tailgate is different but will fit with modification. you will need to change the hinges and some shimming may be required to make the body lines match.
Offline 80stepsideguy
« Reply #4 on: October 08, 2008, 02:52:38 am »
With the world of modifications and customization go for it man the cheaper the better.
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline txtj79
« Reply #5 on: October 08, 2008, 04:49:21 pm »
So, if I have my original tailgate from my 76 (damaged), can I use the parts from it to make the 82 fit?
Thanks for all the responses....
-T.J.
« Reply #6 on: October 08, 2008, 05:02:56 pm »
Yes.
Offline kcwis
Re: Will a '82 tailgate fit a '76 truck??? 76 tailgate not available
« Reply #7 on: April 13, 2017, 02:45:28 pm »
We have a 76 gmc c15 1'2 ton 2wd without a tailgate and have a newer tailgate we'd like to use,It has the guide attached to the latch,  does anyone have a picture of what is needed to convert it?
« Last Edit: April 13, 2017, 06:16:05 pm by VileZambonie »
Offline kcwis
« Reply #9 on: April 13, 2017, 04:05:35 pm »
Thanks for the tailgate pics, can I get some pics of whats needed on the bed?
« Reply #10 on: April 13, 2017, 06:21:16 pm »
You say you have a newer tailgate, what year gate is it? You need the trunions and hinges for 81-87 if it is that style gate.
Offline kcwis
« Reply #11 on: April 13, 2017, 09:52:37 pm »
I think late 70's it has the guide as part of the latch.
« Reply #12 on: April 14, 2017, 07:36:28 am »
Post pics
Offline kcwis
« Reply #13 on: April 26, 2017, 03:42:19 pm »
Sorry can't post pics but did get tailgate to fit except needs to be raised to meet sides,adjusted trunnion as hi as it will go,do we need to re-drill mounting holes?
« Reply #14 on: April 26, 2017, 07:19:30 pm »
Not enough info. What did you do, did you replace the hinges and trunions for an 81- up gate? Why can't you post pics?
