Body, Glass & Paint
Will a '82 tailgate fit a '76 truck???
Topic: Will a '82 tailgate fit a '76 truck??? (Read 17617 times)
txtj79
1980 Chevy C-10 SWB
October 07, 2008, 08:59:32 pm »
I have a 76 C-10 and I need a tailgate. Found one on craigslist for an 82. Will it fit? Is the latch system and mounting the same?
Thanks,
T.J.
zieg85
Re: Will a '82 tailgate fit a '76 truck???
October 07, 2008, 09:13:48 pm »
the latch is slightly different I believe.
ccz145a
October 07, 2008, 10:56:01 pm »
trunions are different, too. good news is the right ones will bolt on. pretty sure the latch will work, but you need to bolt on '82 drop bars.
October 07, 2008, 10:56:38 pm »
The tailgate is different but will fit with modification. you will need to change the hinges and some shimming may be required to make the body lines match.
80stepsideguy
October 08, 2008, 02:52:38 am »
With the world of modifications and customization go for it man the cheaper the better.
thanks
pat
1998 Chevy 1500 S/B 2wd
txtj79
1980 Chevy C-10 SWB
October 08, 2008, 04:49:21 pm »
So, if I have my original tailgate from my 76 (damaged), can I use the parts from it to make the 82 fit?
Thanks for all the responses....
-T.J.
October 08, 2008, 05:02:56 pm »
Yes.
kcwis
Re: Will a '82 tailgate fit a '76 truck??? 76 tailgate not available
April 13, 2017, 02:45:28 pm »
We have a 76 gmc c15 1'2 ton 2wd without a tailgate and have a newer tailgate we'd like to use,It has the guide attached to the latch, does anyone have a picture of what is needed to convert it?
zieg85
April 13, 2017, 03:04:51 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6065.0
*edited link*
Last Edit: April 13, 2017, 06:16:05 pm by VileZambonie
kcwis
April 13, 2017, 04:05:35 pm »
Thanks for the tailgate pics, can I get some pics of whats needed on the bed?
April 13, 2017, 06:21:16 pm »
You say you have a newer tailgate, what year gate is it? You need the trunions and hinges for 81-87 if it is that style gate.
kcwis
April 13, 2017, 09:52:37 pm »
I think late 70's it has the guide as part of the latch.
April 14, 2017, 07:36:28 am »
Post pics
kcwis
April 26, 2017, 03:42:19 pm »
Sorry can't post pics but did get tailgate to fit except needs to be raised to meet sides,adjusted trunnion as hi as it will go,do we need to re-drill mounting holes?
April 26, 2017, 07:19:30 pm »
Not enough info. What did you do, did you replace the hinges and trunions for an 81- up gate? Why can't you post pics?
Body, Glass & Paint
