Interior & Equipment
Heating, Ventilation & Air Conditioning (HVAC)
Still no blower motor updated pics
4
5
6
Topic: Still no blower motor updated pics (Read 46678 times)
Re: Still no blower motor updated pics
Reply #60 on:
December 05, 2013, 07:09:28 pm »
Are you sure you have the correct squirrel cage on the blower and it's not binding?
Reply #61 on:
December 05, 2013, 07:10:20 pm »
Look on the bright side, you've got most of it fixed/figured out as you've had a multitude of problems.
darmentle
Reply #62 on:
December 05, 2013, 07:11:59 pm »
yeah thanks for the help i will pick up a blower this weekend and update you
darmentle
Reply #63 on:
December 07, 2013, 01:25:30 pm »
I got it working but now the squirll cage is rubbing in side the blower box. If i back the screws off it doesn't rub is there suppose to be some kind of spacer that goes between the two?
Reply #64 on:
December 07, 2013, 01:45:16 pm »
There shouldn't be any spacer. Do you have the correct squirrel cage on there? Is it new or old?
darmentle
Reply #65 on:
December 07, 2013, 01:56:27 pm »
it is old i just broke it so now i have to get a new one its like its to long for the box.
Reply #66 on:
December 07, 2013, 02:01:13 pm »
Where did you get the blower motor from? If you get an aftermarket fan make sure you get a standard rotation and just check the length since they are typically universal.
darmentle
Reply #67 on:
December 07, 2013, 02:08:16 pm »
i got the new one from oreillys its the same as the old one.
Reply #68 on:
December 07, 2013, 02:12:41 pm »
Although it may look the same as the old one it probably has the cage sit up higher.
darmentle
Reply #69 on:
December 07, 2013, 03:31:28 pm »
here a pic maybe that will help. i stopped at the parts store and they don't carry them in stock.
Reply #70 on:
December 07, 2013, 04:39:09 pm »
Where are you located?
darmentle
Reply #71 on:
December 07, 2013, 04:51:53 pm »
Redding ca i know the pick n pull doesn't have my truck out there. Is it possible maybe a older Chevy car cage would work like a camero or a elcamino or a chevy van?
Last Edit: December 07, 2013, 04:55:59 pm by darmentle
Reply #72 on:
December 07, 2013, 11:42:25 pm »
Go to Napa
http://www.napaonline.com/Catalog/Result.aspx?Ntt%3dblower%26Ntk%3dKeyword%26Nty%3d1%26Dn%3d0%26D%3dblower%26Dk%3d1%26Dp%3d3%26N%3d0
darmentle
Reply #73 on:
December 08, 2013, 09:39:29 am »
found a donor truck here my town the guy is gonna come let me pull the heater parts off for 20$
darmentle
Reply #74 on:
December 08, 2013, 04:02:59 pm »
Sweet i got it working finally !!!! So the will i got was the right one , the one that was in there was way to big. i need to take a look and check see if the ducting under the dash was removed. but drove it around just now and with in 8 min it got nice and toasty in side . thanks again vile.
4
5
6
